Newtons Laws and acceleration
In summary, the pine tree air freshener hanging from the rear view mirror makes an angle of 27.9 degrees with the vertical while a car is accelerating. The car's acceleration is approximately 0.529 m/s^2 and the tension in the string of the 100g air freshener is 0.11315 N. According to the law of inertia, the air freshener moves with the same acceleration in the opposite direction. The correct calculation for the tension is 1.11 N and the correct calculation for the acceleration is 11.1 m/s^2.
waldvocm
76
The pine tree air freshener hanging from the rear view mirror makes an angle of 27.9 degrees with the vertical while a car is acceleration
a)What is the car's acceleration
ax=gsin(theta)=9.80*sin(27.9)=4.59
b)What is the tension in the string of the 100g air freshener?
ax=T/m=4.59(100)=T
T=458 (Or does the mass always have to be in kg?) T=.458
According to the law of inertia, when the car moves forward with an acceleration a. the freshener moves with the same acceleration in reverse direction. If T is the tension in the string, them in the equilibrium condition
ma = T*sinθ and mg = T*cosθ. Here m must be in kg.
Now solve for T and a.
.10=T(cos(27.9)) T=.11315
.10a=.11315(sin(27.9)) a=.529
Is this correct?
Is this correct?
No. It is not correct.
0.10*g = T(cos(27.9))
.10(9.80)=T(cos(27.9)) T=1.11
a=T/m a=11.1
Write down the units.
Check the calculations. T*sinθ = ma.
1. What are Newton's three laws of motion?
Newton's first law states that an object at rest will remain at rest, and an object in motion will remain in motion at a constant velocity, unless acted upon by an external force. The second law states that the force acting on an object is equal to the mass of the object multiplied by its acceleration. The third law states that for every action, there is an equal and opposite reaction.
2. How do Newton's laws apply to acceleration?
Newton's second law, also known as the law of acceleration, states that the acceleration of an object is directly proportional to the net force acting on the object and inversely proportional to its mass. This means that the greater the force acting on an object, the greater its acceleration will be. Additionally, the greater the mass of an object, the slower its acceleration will be.
3. Can an object have acceleration without a net force?
No, according to Newton's first law, an object at rest will remain at rest unless acted upon by an external force. Similarly, an object in motion will continue moving at a constant velocity unless acted upon by an external force. Therefore, in order for an object to have acceleration, there must be a net force acting on it.
4. How do Newton's laws explain the concept of inertia?
Newton's first law, also known as the law of inertia, explains the concept of inertia. Inertia is the tendency of an object to resist changes in its state of motion. This means that an object will remain at rest or in motion at a constant velocity unless acted upon by an external force, as stated in Newton's first law.
5. Can an object have acceleration without changing its speed?
Yes, an object can have acceleration without changing its speed if the direction of the object's velocity changes. This is known as centripetal acceleration, where the object is continuously changing direction but maintains a constant speed. This can be observed in circular motion or when an object is moving in a curved path.
