How Do Newton's Laws Apply to a Block and Toboggan on a Frictionless Surface?
In summary, the block is accelerated by 10 m/s^2 when it is pulled by a 30 N-force, and the toboggan is also accelerated by 2.5 m/s^2.
aal0315
41
A 4.0 kg toboggan rests on a frictionless icy surface, and a 2.0 kg block rests on
top of the toboggan. The coefficient of static friction between the block and
the surface of the toboggan is 0.60, whereas the kinetic friction coefficient is
0.51. The block is pulled by a 30 N-horizontal force as shown. What are the
magnitudes and directions of the resulting accelerations of the block and the
toboggan?
Fnet = F-Ffr = ma
Ffr = μk*Fn
I found that the box will move ontop of the toboggan because μs *Fn = 11.76 N which is less than 30 N so the box will move.
F-Ffr = ma
30N - 10.0N = 2.0 kg (a)
accel. = 10 m/s^2
so i know that's the box on the toboggan. How do i find the toboggan on the ground?
do i just do it as
F-Fr = (Mb +Mt) *a
30 - 10 = (2.0 + 4.0) *a
20 = 6.0 *a
a = 3.33m/s^2
does that make sense at all? any help would be great.
thanks
I agree with your a = 10 for the box.
But isn't the friction force of 10 N the only force on the toboggan? That is the "grip" the pulling system (including the box) has on it. I would apply F = ma to the toboggan with F = 10.
I don't really understand the "grip" pulling system. I don't understand why the F = 10N. wouldn't the toboggan still move in the same direction as the box because 30N is greater than 10N?
can someone please help me with this question? i just need to know if this is right or not or if I am completely wrong and need to start again
Have you drawn free body diagrams for these? It might help clear it up if you haven't...
well I am not sure about the FBD of the toboggan. i figured out the block one though. The above calcuations for the toboggan that i did i guess is not right?
i figured that there would still be the force of 30N west and the force of friction against it, so the total force is 20N west.
is the above correct?
The 30N are only working on the block... what is pulling the toboggon forward?
Block: - Friction + 30 = m*a
Toboggan: Friction = m*b (where b is the acceleration of the tobagan)
Friction = .51*2*g = 10
so the block accelerates at 10 m/s^2 and the toboggan accelerates at 2.5.
does that mean that the toboggan is moving east and the block is moving west? because i need to find the directions of the accelerations as well.
Both move the same way. The way the 30 N pull is exerted. You haven't said which way that is.
I answer your question with a question of my own:
What way is the friction between the box and the toboggon acting on the toboggon?
i guess the friction between the box and toboggan will act in the opposite direction on the toboggan and ground?
little confused.
how do i find the directions of the accelerations?
The ground is not involved - frictionless.
The friction between the box and the toboggan acts one way on the box and the other way on the toboggan. It opposes the motion of the box and causes the motion of the toboggan.
delphi is right, accel would be in the same direction of friction because the ground is frictionless...
ok so let me just sure i have this right
accel box = 10m/s^2 to the left
accel toboggan = 2.5 m/s^2 to the left?
*friction acting on the toboggon
yes, you would be correct
thank you for the help :eek:)
1. What are Newton's three laws of motion?
Newton's three laws of motion are principles that describe the behavior of objects in motion. They are: 1) an object will remain at rest or in uniform motion in a straight line unless acted upon by a net external force; 2) force is equal to mass times acceleration; and 3) for every action, there is an equal and opposite reaction.
2. How do Newton's laws affect the motion of objects?
Newton's laws explain the relationship between force, mass, and motion. They can be used to predict how an object will behave when forces act upon it. These laws are the basis for understanding the motion of objects in everyday life and in more complex systems, such as those in space.
3. What is the role of friction in Newton's laws?
Friction is a force that opposes motion and is an essential part of Newton's laws. It is responsible for slowing down or stopping the motion of objects and is present in all situations where two surfaces come into contact. Friction is necessary for many everyday tasks, such as walking, driving, and even writing with a pen.
4. How does friction affect the motion of objects?
Friction can either increase or decrease the motion of an object, depending on the direction of the force and the surface it is acting on. For example, when two surfaces slide against each other, friction acts in the opposite direction, slowing down the motion. On the other hand, when the force of friction is used to push an object, it can increase its motion.
5. Can friction be reduced or eliminated?
Friction can be reduced through various methods, such as using lubricants, smoother surfaces, or changing the type of materials in contact. However, it cannot be eliminated entirely as it is a natural force present in all interactions between surfaces. In some cases, friction is necessary for safety and functionality, such as the friction between car tires and the road to prevent slipping.
