How Do Newton's Laws Apply to a System of Hanging Masses?
How can you use these values to find the displacement? In summary, this conversation involves the problem of finding the tension in a cord connecting two boxes and the distance traveled by another box in a given time period. The solution involves using the equations F=ma and F=mg to find the acceleration and then using the equation a=v/t to find the displacement.
cartoonorange
Three ballot boxes are connected by cords, one of which wraps over a pulley having negligible friction on its axle and negligible mass. The masses are mA = 32.0 kg, mB = 40.0 kg, mC = 18.0 kg. (box a is on the horizontal suface and b and c hang down.
(a) When the assembly is released from rest, what is the tension in the cord that connects boxes B and C?
(b) How far does box A move in the first 0.250 s (assuming it does not reach the pulley)?[/B]
F=ma
First I found acceleration.
T=Mass of box a * acceleration
F gravity = (mass of b + mass of c) * g
T-F gravity = (Mass of b + mass of c) * -accelleration
acceleration=((mass of b + mass of c) *g)/(mass of a +mass of b + mass of c)
a=(58 * 9.8)/(32 + 40 + 18)=6.68
T=ma
T=32 * 6.68=187 N
and that's as far as I got
Welcome to Physics Forums,
A hint for part (b): you know the acceleration of box A as well as the initial velocity and the time period.
I would like to clarify that this problem involves the application of Newton's Laws of Motion, specifically the second law, which states that the net force acting on an object is equal to its mass multiplied by its acceleration (F=ma). In this case, we have three masses connected by cords, and we need to determine the tension in one of the cords and the acceleration of the system.
To solve for the tension in the cord connecting boxes B and C, we first need to find the acceleration of the system. This can be done by considering the forces acting on the masses. The only external force acting on the system is gravity, which pulls down on boxes B and C. The tension in the cord connecting boxes B and C is equal in magnitude to the force of gravity on boxes B and C (since the system is at rest). Therefore, we can set up an equation using Newton's second law:
T = (mB+mC)g
where T is the tension in the cord, mB and mC are the masses of boxes B and C, and g is the acceleration due to gravity. Substituting the given values, we get T = (40+18) * 9.8 = 548 N.
To solve for the acceleration of the system, we can use the same equation, but this time, the net force acting on the system is the difference between the tension in the cord and the force of gravity on box A. Therefore, our equation becomes:
(mB+mC)g - mA*g = (mB+mC+mA)a
Substituting the given values and solving for a, we get a = ((40+18+32) * 9.8)/(40+18+32) = 6.68 m/s^2.
To solve for the distance that box A moves in the first 0.250 s, we can use the equation of motion:
x = x0 + v0t + 0.5at^2
where x0 is the initial position, v0 is the initial velocity (which is zero in this case), a is the acceleration we just calculated, and t is the time. Substituting the given values, we get x = 0 + 0 + 0.5*6.68*(0.250)^2 = 0.208 m.
In conclusion, the tension in the cord connecting boxes B and C is
1. What are Newton's Laws of Motion?
Newton's Laws of Motion are three fundamental principles that describe the behavior of objects in motion. The laws were described by Sir Isaac Newton in the late 17th century and are still used to explain the motion of objects in the world today.
2. What is the first law of motion?
The first law of motion, also known as the law of inertia, states that an object at rest will remain at rest and an object in motion will remain in motion at a constant velocity unless acted upon by an external force.
3. How does tension relate to Newton's Laws of Motion?
Tension is a force that acts upon an object when it is pulled or stretched. According to Newton's second law of motion, the acceleration of an object is directly proportional to the net force acting on it. Therefore, the amount of tension applied to an object can affect its acceleration.
4. Can tension be greater than the weight of an object?
Yes, tension can be greater than the weight of an object. Tension is a force that is applied to an object, while weight is a force that is exerted on an object by gravity. The two forces can act in different directions and have different magnitudes.
5. How can I calculate the tension in a system using Newton's Laws of Motion?
To calculate the tension in a system, you need to consider the forces acting on the object and apply Newton's second law of motion, which states that the net force on an object is equal to its mass multiplied by its acceleration. By rearranging the equation, you can solve for tension by subtracting the weight of the object from the net force acting on it.
