Homework Help: Newton's laws (I think!)
  1. Sep 20, 2007 #1
    A rocket car is developed to break the land speed record along a salt flat in Utah. However, the safety of the driver must be considered, so the acceleration of the car must not exceed 5g (or five times the acceleration of gravity) during the test. Using the latest materials and technology, the total mass of the car (including the fuel) is 6000 kilograms, and the mass of the fuel is one-third of the total mass of the car (i.e., 2000 killograms). The car is moved to the starting line (and left at rest), at which time the rocket is ignited. The rocket fuel is expelled at a constant speed of 900 meters per second relative to the car, and is burned at a constant rate until used up, which takes only 15 seconds. Ignore all effects of friction in this problem.
    Find the acceleration a_0 of the car just after the rocket is ignited.
    Express your answer to two significant figures.
    2. Relevant equations
    F=ma, Rate of fuel consumption = 400/3
    3. The attempt at a solution
    In 15s, 2000Kg of fuel is burnt so in one second, it is 400/3.
    Velocity is 900m/s so change in momentum will be 120,000.
    This divided by mass will give you 60Kg. Am I right or not? I just do not know!!
    Thanks a lot for your time and effort.
  3. Sep 20, 2007 #2
    Doc Al
    Staff: Mentor
    OK, that's dm/dt.
    OK, that's the thrust, in Newtons.
    What mass did you use? (Acceleration has units of m/s^2.)
  4. Sep 20, 2007 #3
    It says initial so I used a mass of 2000 which now I realize is a mistake. It should be 6000 and the answer comes to 20m/s^2. Is that right?
  5. Sep 20, 2007 #4
    Doc Al
    Staff: Mentor
    No. Use the total mass.
  6. Sep 20, 2007 #5
    The total mass is 6000 isn't it?
  7. Sep 20, 2007 #6
    Doc Al
    Staff: Mentor
    My bad... you're right. That includes the fuel.
Loading...
