Why is Newton's 3rd Law of Motion important in physics?
In summary, the conversation discusses Newton's laws of motion and how they apply to two identical tin cans pressed against each other. It is also mentioned that deformable objects may not behave identically due to small differences in structure and mass. The conversation then shifts to discussing falling objects and how their acceleration can indicate whether they have experienced resistance or not. Ultimately, the group advises the individual to focus on rigid bodies and frictionless surfaces when studying Newton's laws.
mindfilter
Hey guys.
I have long since realized that my interest and fascination for physics in general outweighs my mathematical skills by far. And since logic and common sense only gets you so far, I reach out to you with a sincere hope that you might help me see things more clearly.
I'll start off easy with some well known laws in classical mechanics -- Newton's laws of motion.
Newton's 3rd law of motion states that for every action there is an equal and opposite reaction. Now, if I understand this law correctly, if I was to press two identical tin cans against each other, they would, at least in theory, crumble simultaneously and similarly. Is this correct?
Does it make a difference if one tin can is in motion while the other one is not? It is my understanding that speed is irrelevant, as per Newton's 2nd law, but I might be mistaken.
Finally, are there any circumstances in which one of the tin cans would sustain substantially more damaged by the impact than the other, given that they are identical in structure and mass, and assuming the point of impact is the same for both?
Regards,
mindfilter
Yes (although some might say it depends on the theory).
Makes no difference.
It's very hard to find something that isn't in motion. How would you define a stationary can? Remember the Earth is spinning, moving around the sun, and the galaxy...
Yes. It's possible that the outcome is "sensitive" to very small differences. Consider two glasses bashed together. The moment one starts to shatter it stops or considerably reduces the force it applies on the other. So a very small defect/difference between the two might make a large difference to the outcome.
Consider a length of fishing line in tension. The line and the tension should be identical everywhere along it's length but it almost never snaps in multiple places at once, only in the one place that has a microscopic defect (such as a knot or abrasion might introduce).
Some quite deep theories say no two objects can ever be 100% identical right down at the atomic scale.
But if they were, then yes, you would see them deform identically.
I think as you are just beginning study Newton's laws, it is not good idea to examine cases with deformable objects as it can easily confuse you. Also in your example the forces are not direct, (you push cans, they push each other). It is better to think of pushing rigid bodies, frictionless suracess etc.
Ok, I'd like to stick with deformable objects, because my questions are related to an actual event, and it is this possible confusion I want to address.
With regard to Newton's 2nd law of motion, am I right to assume that any falling object (with no other external forces applied) with an observed acceleration equal to the gravitational acceleration (g) can not have met any resistance on its path?
Thanks,
mindfilter
Thanks,
mindfilter
No - any constant mass object which does not have an acceleration equal to g is "meeting resistance" at that time. Any constant mass object which is accelerating at g, is not meeting resistance at that time. It's present acceleration tells you nothing about its past history.
To avoid double negatives...
Lets say you drop something (initial velocity zero) off a building of height (h) and it hits the ground after time (t). You can work out the average acceleration the object experienced.
If the answer is equal to g (9.81m/s^2) then yes you can say it probably experiened no (or negligible) resistance on the way down.
If the answer is less than g some resistance was experienced.
If more than g the object was somehow propelled downwards.
Please reassure us this has nothing to do with 911 and falling buildings! It's been done to death elsewhere.
PS: Note RAPs comments about instantaneous acceleration not telling you about past acceleration.
Good point - if the average downward acceleration over a path is equal to g, then it has experienced no resistance over that path. If its less, it has.
1. What are Newton's laws of motion?
Newton's laws of motion are a set of three physical laws that describe the behavior of objects in motion. They were developed by Sir Isaac Newton in the 17th century and are considered the foundation of classical mechanics.
2. What is the first law of motion?
The first law of motion, also known as the law of inertia, states that an object at rest will remain at rest and an object in motion will remain in motion at a constant velocity unless acted upon by an external force.
3. What is the second law of motion?
The second law of motion, also known as the law of acceleration, states that the acceleration of an object is directly proportional to the net force acting on the object and inversely proportional to its mass.
4. What is the third law of motion?
The third law of motion, also known as the law of action and reaction, states that for every action, there is an equal and opposite reaction. This means that when two objects interact, the forces they exert on each other are equal in magnitude and opposite in direction.
5. How are Newton's laws of motion used in everyday life?
Newton's laws of motion are used in many everyday activities, such as driving a car, playing sports, and riding a bike. They are also essential in engineering and designing structures, machines, and vehicles. In essence, these laws help us understand and predict the behavior of objects in motion, making them crucial in our daily lives.
  • Mechanics
