Homework Help: Newtons Method In Matlab
  1. Oct 7, 2012 #1
    I'm tasked currently with creating a matlab function to run newton's method. From there I need to use this function to solve for the constants of a catenary which pass through (+-50, 100). I used wolfram alpha to find the proper constant as 107.432 so I would know if I was on the right track or not.
    The equations I'm given:
    [tex]x=t[/tex]
    [tex]y=c*cosh(\frac{t}{c})-c[/tex]
    I computed the derivative to be
    [tex]\frac{dy}{dt}=sinh(\frac{t}{c})[/tex]
    This is the code I have thus far:
    Code (Text):
    function result = newton(x, epsilon, imax)
    %NEWTON Performs newton's method like a boss
    %   Detailed explanation goes here
    %c=107.43201882596103613561001;
    i = 1;
    fprintf('Newtons Method Iterations: %i\n', imax);
    while(i<=imax)
        root = (x - (csc349_asgn3_fy(x,c)/csc349_asgn3_fpy(x,c)));
        fprintf('Iteration: %i, Root: %2.10f\n', i, root);
        if(abs(1-(x/root))<epsilon)
            result = root;
            return
        end
        i=i+1;
        x=root;
    end
    fprintf('FAILED TO CONVERGE IN GIVEN ITERATION LIMIT\n');
    end
    The functions csc349_asgn3_fy(x,c), and csc349_asgn3_fpy(x,c) respectively represent the function y and the derivative.
    Code (Text):
    function result = csc349_asgn3_fy(t,c)
    %CSC349_ASGN3_FY function to be fed into newtons method
    result = c*cosh(t/c)-c;
    end
    Code (Text):
    function result = csc349_asgn3_fpy(x,c)
    %CSC349_ASGN3_FPY derivative of function to be fed into newtons method
    result=sinh(x/c);
    end
    Now, I have no idea what to do. I know that I should start with x0 being 50, and the assignment specifies 20 iterations. I've tried a few things, but all the results I have thus far are incorrect.
    From what I see, the constant c just needs to be fiddled with until the function for the y coordinate is equal to 100. I'm not sure how to go about implementing this though.
Draft saved Draft deleted
