Newton's second law
  1. Oct 28, 2006 #1
    hmm....i was wondering is there any conditions for the use of Newton's second law?
  3. Oct 28, 2006 #2
    Doc Al
    Staff: Mentor
    What do you mean?
  4. Oct 28, 2006 #3
    radou
    The 'conditions' which imply the usage of an equation are read from the equation itself. :smile:
  5. Oct 28, 2006 #4
    i dont reali know how to put it in words but erm.......we do not need a varying mass to use F=dmv/dt right?
  6. Oct 28, 2006 #5
    Doc Al
    Staff: Mentor
    Right. F= d(mv)/dt is more general than F=ma, which assumes a non-varying mass.
  7. Oct 28, 2006 #6
    radou
    Well, if the mass is not constant, then you have [tex]\vec{F}=\frac{d}{dt}(m\vec{v})=\frac{dm}{dt}\vec{v}+m\frac{d\vec{v}}{dt}[/tex].
  8. Oct 28, 2006 #7
    Alright i just came across this dumb conditions and i wanted to verify that this is nonsense :rofl: Thanks
  9. Oct 28, 2006 #8
    OlderDan
    An easy calculus problem, but a tricky physics problem. Suppose there is a railroad car coasting with speed V on a straight horizontal track without any rolling friction. The car is full of water and has initial mass Mo and velocity Vo. As the car rolls, the water in the tank leaks out of a hole in the bottom of the tank at a rate we can assume to be constant (maybe the hole gets a little bigger as the water level drops). So the mass M of the car is changing at a constant rate. The only forces acting on the car are gravity and the normal force, both of which are perpendicular to the motion. What happens to the velocity of the car?
