Homework Help: Newtons Theory of Gravity
  1. Oct 22, 2007 #1
    Two spherical asteroids have the same radius R. Asteroid 1 has mass M and asteroid 2 has mass 2.58·M. The two asteroids are released from rest with distance 12.35·R between their centers. What is the speed of second asteroid just before they collide? Give answer in units of (G·M/R)1/2.
    2. Relevant equations
    Ki + Ui = Kf + Uf
    U= -GMm/r
    K= 1/2 m v^2
    3. The attempt at a solution
    My Ki is 0. So I get
    0 -GMm/r1 = 1/2 m vf^2 + -GMm/r2
    r1= 12.35R
    r2= 2R
    so i solved for Vf = sqrt( 2GM (-1/ r1 + 1/r2) )
    and then I get Vf = .915 (GM/R)^(1/2)
    What am I doing wrong, as that is the wrong anwser.
  3. Oct 22, 2007 #2
    G01
    EDIT: ERROR IN THIS POST, see post 6.
  4. Oct 22, 2007 #3
    hmm are you recommending me to work with kinematic equations?
    I do not see where you would go with knowing that information.
    i) o ----------------- o
    f) oo
    I got a hint: You will need to use two conservation laws.
    So I was thinking now I would use momentum and what I had earlier...but not sure if I should. I might need this one spelled out to me...
  5. Oct 22, 2007 #4
    G01
  6. Oct 22, 2007 #5
    umm, 2 times the radius of the mass?
    Which I had as 2R for r2...
  7. Oct 22, 2007 #6
    G01
    SORRY! I was tired and thought you were making a mistake that you weren't! Your values of R are correct! Very sorry!
    I think your problem is in the following fact:
    Remember that the kinetic energy on the right hand side of the equation will be split evenly between BOTH asteroids. What does this tell you?
    Again, very sorry for misleading you. I must have really been out of it then!:redface:
Loading...
