Newton's Third Law and a ball
FeDeX_LaTeX
Hello;
I am a little confused here. A friend asked me that, due to Newton's Third Law of Motion, for every force there is an equal and opposite force. Therefore, why is it, for example, that when we throw a ball up into the air, it moves upwards at all, if the force exerted on the ball upwards is the same downwards (plus gravity)? Same thing for a rocket - if the rocket applies, say, a 10000N force upwards, and if there is a 10000N force downwards acting on the rocket, why does it still move? I just need to get this cleared up as I know I am missing something important here.
Thanks.
Answers and Replies
Rajini
619
moving of rocket (including mass) = downwards force acting on rocket!!..
if force on left side is more then it would move to compensate
mathman
540
The initial impetus gives the ball and the rocket an initial velocity. The forces act to change velocity.
dacruick
1,039
I think a tenth of my posts are regarding newton's third law so you aren't the only one who misses this subtle yet crucial circumstance of the law. When Newton says that there is an equal and opposite force, that does not mean that the forces act on the same object. Everytime you do a pushup, you apply maybe 100 newtons of force. That force pushes you up off the ground. But every time you do that push up, you also apply 100 newtons of force downwards against the earth. But, since the earth weighs so much, it doesn't move at all. Also, everytime you punch a wall. You exert a certain amount of force against that wall, but your hand hurts because that wall exerts that exact same force back to you.
Now think about punching through paper. Maybe you punch paper with 100 newtons of force in your fist. Paper takes about 1 Newton of force to break. So upon punching paper, you lose 1 Newton out of your 100 Newtons of force. Now because your fist carries through the paper, your arm much apply 99 Newtons in the opposite direction to stop your hand. So you can see there is a conservation of force here.
If you have any questions feel free to ask.
Dale
Mentor
Insights Author
2021 Award
33,007
10,254
In Newton's 3rd law the equal and opposite forces act on different objects. So, for the rocket, the 10000 N upwards force on the rocket is equal and opposite to the 10000 N downwards force on the exhaust, which is why the exhaust accelerates down so quickly and the rocked accelerates up. When you throw a ball up it pushes you down, equal and opposite forces acting on different objects.
Oh, looks like dacruick was faster!
FeDeX_LaTeX
Thanks guys! I understand the law a lot better now. But... if I were to take a car travelling with a force of 100N to the right, why must the force to slow the car be more than 100N? Why does it being 100N exactly have no effect?
Dale
Mentor
Insights Author
2021 Award
33,007
10,254
Because the other 100 N acts on the road, not the car.
FeDeX_LaTeX
Okay, what if it was a projectile in the air? Surely the opposing 100N force would cause it to slow? Where else could it be acting on?
Rajini
619
that is the reason why projective doesn't continue forever.
Dale
Mentor
Insights Author
2021 Award
33,007
10,254
The air would push backward on the projectile and the projectile would push forward on the air. Equal and opposite forces on different bodies, always.
jtbell
Mentor
15,890
4,553
The long-winded version of Newton's Third Law: "The force that object 1 exerts on object 2 is equal in magnitude and opposite in direction to the force that object 2 exerts on object 1."
sganesh88
289
@Jtbell
If Newton had postulated the third law in this way,we'd have had half the number of posts in PF. :D
dacruick
1,039
@Jtbell
haha agreed
collinsmark
1,885
Hello FeDeX_LaTeX,
You don't need friction to figure this one out.
At the time you throw a 100 N ball (projectile) into the air, you must exert an extra force on the projectile/ball (above and beyond the ball's weight). At the same time your feet exert the same extra force on the Earth (above and beyond your own weight and the ball's weight), but in the opposite direction.
After you throw the ball in the air, The Earth continues to exert a 100 N force on the ball. So where is the so-called equal and opposite force? The ball exerts a 100 N force on the Earth! The ball is (in part) actually the one bringing the Earth closer to it!
Every time you throw an object into the sky, you are also pushing the earth away from the object at the same time. The distances that each moves is different though. Because the Earth is so much more massive than most objects, it hardly budges. But the Earth does move away from the object just a tad.
You can calculate the acceleration that the earth experiences after you throw an object up by using (assuming you don't throw it very far up, and assuming the object is small compared to the Earth):
[tex] F = mg = Ma [/tex]
where M is the mass of the earth, and a is the acceleration of the Earth caused by the ball.
[tex] a = \frac{mg}{M} [/tex]
So immediately after throwing up a 100 N object into the air, the object experiences an acceleration of 9.8 m/s2 in the down direction, but the Earth experiences a
(100 N)/(5.97 × 1024 kg) = 16.75 × 10-24 m/s2 in the up direction.
The accelerations of the Earth and the ball are obviously different (the acceleration of the Earth is so small, it's not even measurable). But the forces that one causes on the other are identical, except in opposite direction.
So the next time you're tempted to say, "I fell down and hit my head on the ground," you can always rephrase it instead as "The ground came up and hit me on the head." Both have about the same validity. But to be truly accurate, they both happen at the same time. Newton's third law. :smile:
[Edit: The same is true with apples. :wink:]
bp_psy
462
@Jtbell
Actually Newton's explanation of the third law in Principia is very clear and complete.He stresses the fact that the forces are on different bodies. The problem is due to newer textbooks that are not clear or much more often due to the reader not reading the whole paragraph.
jtbell
Mentor
15,890
4,553
Bingo! :biggrin:
malu
hi
i just have simple question suppose if A pushes on B with 10 kn, then B pushes on A with 10 kn, (i am now not bothered about what happned to B) but why does A moves in oppsite direction although it was already carrying a force of 10 kn (that means a force of 10 kn was already on A in the direction of B) and B forced back 10 kn so A should stand still, but we say that it moves back, why ? (we all the time give example that when we push earth, it moves back although by small amount)
Doc Al
Mentor
45,412
1,848
hi
What do you mean by "it was already carrying a force of 10 kn"? Bodies don't 'carry' a force just by virtue of their motion.
If A was moving to right at a constant velocity (before colliding with B), then the net force on A is zero. When A collides with B, B exerts a force on A to the left--so A will accelerate to the left.
sameerpaisari
when a ball is thrown up, it goes up due to the force of us throwing it..but it doesn't stay up in the air..does it..?..it comes down as well..due to the gravity's force..
malu
hi thanks a lot for that reply i understood that.
kindly also tell me when we say that when object A pushes on B and imparts acceleration on B then how long the acceleration will be there on B and after what time B will gain the constant velocity.
Doc Al
Mentor
45,412
1,848
As long as there is a net force on B, B will accelerate. When A stops pushing B, and the net force on B is zero, the acceleration of B will be zero and it will continue moving at constant velocity.
malu
Kindly see the attached picture and tell me what happens in three scenarios.
1. When a force of 20 N applied to a 5 kg block (ignore friction) what is the acceleration of 5kg block and what is the force on it.
2. If the 20 N force is continued on small block the block accelerates and hits the bigger block of 15 kg. what are the forces on smaller and bigger block at the moment of impact.
3. Even after hitting the bigger block the force of 20 N is continued now what is the force and accelerations of smaller and bigger blocks.
waiting for your reply
Doc Al
Mentor
45,412
1,848
The first and the third are straightforward applications of Newton's 2nd law. Why don't you give them a try?
The second is not straightforward. There's no simple way to predict the impact forces during the collision. It depends on the speed of collision, the time involved, the nature of the materials. But, no matter what, we know that at all times the two blocks exert equal and opposite forces on each other.
malu
Kindly assume the time and material and even take an ideal scenario and please tell me what will happen in the second case. Moreover i have tried the 1st and the last case ii just want to check whether what i understood is right or not, if i can understand this than i am through with newtons laws. Please help me out to understand better
Doc Al
Mentor
45,412
1,848
That can be quite complicated. What you can do, if you like, is make up some numbers like so: Assume that the first block is moving at some speed V when it collides with the second block. Assume further that the collision takes some very short time T, after which the blocks move together. Then you can calculate the average impact force during the collision by calculating the impulse delivered to each block.
Excellent. Please describe what you found for the forces in those cases.
malu
the force on small block is 20 N and that causes an acceleration of 4m/sec2 on that block.
now say it travelled for 2 sec and the speed after sec is 8m/sec and then bang !!!!
But if even after the impact the force of 20 N is on what is the force on small and larger block i can not really understand.....
malu
now say it travelled for 2 sec and the speed after 2 sec is 8m/sec and then bang !!!!
please explain further what happens next
Doc Al
Mentor
45,412
1,848
OK.
After the impact, once the two blocks are moving with the same speed, you can again apply Newton's 2nd law. What would be the acceleration of the two-block system?
vaibhav1803
69
Hello;
Thanks.
the "force" and "equal and opposite force" is called action reaction pair and the body moves because the two forces act on different bodies
eg. if u push a cart u apply "action"/"force" on the cart while, the "reaction"/"equal & opp. force" acts on you...
you must have felt it sometime didn't you,
its hard to accelerate a large mass as against a small mass because the large mass gives you back a greater reaction.
malu
OK.
both the block will move at an acceleration of 1m/sec2, i understand that but i want to know when there was a bang the what push did the bigger block exert on smaller block and why in-spite of that pushing back the block, the smaller block continues to move in the direction of bigger block why ???
  • #31
Doc Al
Mentor
45,412
1,848
When the first block hits the second, the second block pushes back with some force. But a push causes an acceleration in that direction, not necessarily motion in that direction. The first block is already moving to the right. Due to the force from the second block, it slows down. But it keeps moving to the right. (Here I assume that the collision is perfectly inelastic--that the blocks stick together.)
Perhaps you are thinking that just because there's a force acting on something, that something must move in the direction of the force? Not necessarily.
  • #32
malu
how much maximum force with which bigger block can push on samller Block? i mean on what does that depend.
in other terms what can be the maximum push back bigger block can offer?? considering everything a ideal scenario
  • #33
Doc Al
Mentor
45,412
1,848
The faster the speeds of the blocks change, the greater the force required. If the blocks are squishy, the time of collision might be relatively large and thus the force relatively small. There's no such thing as an 'ideal scenario'--it depends on the material.
Note that it's not simply the force that the blocks exert on each other that matters--it's also the time over which that force acts. Force X time gives you the impulse--the change in momentum.
I'm still trying to get at your real question. There's something you think doesn't quite make sense. What is it?
  • #34
malu
perhaps what you said is correct, but when i ask myself that question, then a simple query comes to my mind, what happens at that moment when there is an impact (considering material has no affect, let me take for time being),
1. Whether the acceleration and velocity of smaller block goes zero. and then with in that same moment (or in the just next moment )the force of 20 N again takes over and then the both block move together.
2. So my question is if the acceleration and velocity of smaller object goes zero at that moment then is it dependent on the mass of bigger object ? (that means capacity of bigger object to impart deceleration on smaller object).
3. To put it in other terms suppose if 5 kg block is moving at an velocity of 1m/sec and then how much mass is required to make the velocity zero.
  • #35
Doc Al
Mentor
45,412
1,848
Why would you think the velocity of the smaller object goes to zero?
Treating this as a simple inelastic collision, there is no mass that will make the velocity equal to zero.
Suggested for: Newton's Third Law and a ball
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
