Newton's third law sign convention: F_AB = F_BA or F_AB = -F_BA
6 replies · 2K views
Mr Davis 97
Imagine that I am pushing on a wall. Then my textbook says that by Newton's third law, ##F_{AB} = F_{BA}##, where I am B and the wall is A. Isn't this wrong? Shouldn't it be that ##F_{AB} = -F_{BA}##?
Sure, if they are using ##F## to represent the forces as vectors. Perhaps they were just talking about the magnitudes of the forces, which are equal.
Ah, I see. I guess it can get kind of ambiguous.
Most introductory textbooks use boldface or arrows on top to denote vectors: $$\mathbf{F}_{AB} = -\mathbf{F}_{BA}\\{\vec F}_{AB} = - {\vec F}_{BA}$$ versus unadorned italics for magnitudes (scalars): $$F_{AB} = F_{BA}$$
Newton's Third Law: For every force acting, there is an equal and opposite force acting. Equal in magnitude, opposite in direction.
Since the "opposite in direction" is often taken as a given, other descriptions generally concentrate on the magnitude, and so FAB = FBA.
If there is a diagram showing the opposite arrows, they are often meant to indicate the convention for positive direction of each force individually. So the later math doesn't use vectors in one coordinate system, but factors for the indicated unit vectors. A negative result then indicates that the force is opposite to its arrow in the diagram.
The thing is, for a given object (free body diagram) that force only applies once. If you stick with the data you've been given in any question or practical situation, the sign of any force is either given or is calculable. You can give an 'unknown' an arbitrary sign and the calculation will produce the correct sign eventually.
