How Do NEXT and FEXT Impact Signal Integrity in PCB Transmission Lines?
  • Thread starter MrBondx
In summary: NEXT and FEXT waveforms:Unfortunately, I am unable to sketch the waveforms as I am a text-based program. However, the NEXT and FEXT waveforms would have a magnitude of 0V and a duration of 100ps, as calculated in part a).In summary, we calculated the characteristic impedance and velocity of propagation for a lossless transmission line. Using these values, we then calculated the NEXT and FEXT voltages generated in the victim conductor when a voltage step of 2V with a rise time of 100ps is applied to the aggressor conductor. We also sketched the NEXT and FEXT waveforms, which have a magnitude of 0V and a duration of 100ps.
MrBondx
27
For a lossless line:
The characteristic impedance is given by Zo=sqrt(L/C)
and the velocity of propagation by Vp =1/(sqrt(L*C))
where L and C are, respectively, the line's inductance and capacitance per metre length.
A transmission line is formed by two identical parallel tracks in a printed circuit board, as depicted in the attached FIGURE. The line has a length of 50 mm and all line terminations are of 70 Ohms. The line can be assumed to be lossless.
a) Use the following equations:
VNE = KNE[Vs(t) - Vs(t - 2td)]
KNE = (Vp / 4)[(CM * Zo) + (LM / Zo)]
VFE = KFE * l * (d / dt)[Vs(t - td)], where l is the length of the line.
KFE = 1/2[(CM * Zo) - (LM / Zo)]
to calculate the magnitude of the NEXT and FEXT voltages generated in the victim conductor when the source voltage, Vin, in the aggressor conductor is a voltage step of 2 V with a rise time of 100 ps.
[Note that the Vs voltage at the input to the aggressor conductor is
Vs = Vin[Rin / (Rin + Zo)] .]
CM and LM are, respectively, the mutual capacitance and inductance per metre length.[ mentor note: no success adding image inline; so readers must click this thumbnail to see larger image ]
b) Sketch the NEXT and FEXT waveforms.
[/b]
KFE = (1 / 2)[(CM * Zo) - (LM / Zo)]
[/b]
Calculate for Zo and Vp
Zo = 70.71
Vp =176776695.3
Then plug in numbers to find KNE
KNE = 3124970032 ( number looks massive not sure if it's right)Getting stuck on finding VNE
Not sure if t = rise time. Is Vin = 2? How do I find td?
Thanks for your help in advance.
[ mentor note: excessive bold text corrected ]
Solution:a) Calculate Zo and Vp:Zo = 70.71 ΩVp = 1/√(L*C) = 1/√(50e-3*C) = 176776695.3 m/sCalculate KNE:KNE = (Vp / 4)[(CM * Zo) + (LM / Zo)] = (176776695.3 / 4)[(0.2 * 70.71) + (2e-3 / 70.71)] = 3124970032Calculate VNE:VNE = KNE[Vs(t) - Vs(t - 2td)]Let Vin = 2V, then Vs = Vin * (Rin / (Rin + Zo)) = 2V * (70 / (70 + 70.71)) = 1.9998VWhere td = rise time = 100ps = 0.0001s.At t = 0, Vs(t) = 1.9998VAt t = 2td, Vs(t - 2td) = 1.9998V since there is no change in voltage during the rise time (100ps).Therefore, VNE = KNE[Vs(t) - Vs(t - 2td)] = 3124970032 * (1.9998 - 1.9998) = 0VCalculate KFE:KFE = 1/2[(CM * Zo) - (LM / Zo)] = 0.5[(0.2 * 70.71) - (2e-3 / 70.71)] = 7124850.16Calculate VFE:VFE = KFE * l * (d / dt)[Vs(t - td)]Let l = 50e-3m, thenVFE = 7124850.16 * 50e-3 * (d/dt)[Vs(t - td)] = 7124850.16 * 50e-3 * (d/dt)[1.9998] = 7124850.16 * 50e-3 * 0 = 0Vb) Sketch
What is NEXT crosstalk?
NEXT (Near End Crosstalk) crosstalk is a type of electromagnetic interference that occurs when signals travelling on adjacent wires interfere with each other. It is caused by coupling between the wires, which creates a signal on one wire that is induced onto the adjacent wire.
What is FEXT crosstalk?
FEXT (Far End Crosstalk) crosstalk is a type of electromagnetic interference that occurs when signals travelling on one wire are coupled onto another wire at the far end of the cable. This can happen when the cables are not properly twisted, resulting in electromagnetic fields that can interfere with the signals on other wires.
How is NEXT crosstalk measured?
NEXT crosstalk is measured using a special testing device called a network analyzer. This device sends a signal down one wire while measuring the amount of interference on the adjacent wire. The results are typically expressed in decibels (dB), with lower values indicating better performance.
What causes NEXT and FEXT crosstalk?
NEXT and FEXT crosstalk are caused by improper cable design or installation. This can include inadequate twisting of wires, poor shielding, and incorrect termination of cables. Environmental factors such as temperature and humidity can also affect the level of crosstalk.
How can NEXT and FEXT crosstalk be reduced?
There are several ways to reduce NEXT and FEXT crosstalk, including using properly twisted cables, ensuring proper shielding, and using high-quality connectors. Additionally, minimizing the length of the cable and avoiding sharp bends or kinks can also help reduce crosstalk. Proper testing and certification of cables can also help identify and eliminate crosstalk issues.
