What Color Will NIR Laser Goggles Be?
In summary, colors are a result of reflected wavelengths and in the case of laser goggles, the color of the goggles depends on the wavelength they are designed to block. For 785nm, goggles can come in blue, green, or clear. The clear option is achieved through the use of interference filters, which are more expensive but can block specific wavelengths while allowing others to pass through. However, they are also more prone to scratch damage. Poly-carbonates are also used for blocking infrared light and are clear, which is why goggles for NIR are not tinted.
lucas_
413
23
Colors come about because the wavelength is reflected off the object while the rest is absorbed. So orange looks orange because the orange is reflected while rest absorbed.
For laser goggles that is rated for say 532nm (green wavelength). It must absorb the 532nm and so the reflected color won't be green but other colors.
What if the wavelength is 785 nm Near Infrared (visible light is up to 700nm only). What should the color of the goggles?
You can still see slight trace of red for 785nm. But not for longer wavelength. I know the light you see is only 1% of the full intensity of the laser hence I know infrared laser have more safety concerns.
Science news on Phys.org
If the Laser wavelength is near the visible range, generally the goggles will be tinted near the opposite end of the visible spectrum. If far away from the visible spectrum the goggles often appear clear, because we don't see the light they block anyhow.
The other important characteristic is how much of the light is blocked. The more powerful the light source the more you want to block. This characteristic is known as Optical Density or OD. OD is on a logarithmic scale. OD of 1 let's thru 1/10 of the light and an OD of 3 let's thru 1/1000. Common density range of goggles for electric arc welding is 5 to 14.
Anyhow, a quick Google search revealed for 785nm they are available in Blue, Green, or Clear.
Cheers,
Tom
Cheers,
Tom
I know about the Optical Density and even the formula for determining it given laser wavelength and power.
Why do you think the 785 come in blue or green color? Does it help in suppressing the 785 nm? Or is it only for cosmetic purpose?
Many color-selective filters have a fairly wide wavelength (color) band, they are cheaper to make that way. The wideband filters for 785nm would overlap the visible Red wavelengths and block them. When Red-Orange is removed from White light you have Green-Blue left, that's all there is to see.
Ok. But you mentioned there was also clear. Why is there clear?
lucas_ said:
Why is there clear?
They are probably made by building up multiple layers of two materials that have a different refractive indices. The individual layer thicknesses are selected to be 1/4 wavelength thick at the wavelength to be blocked. This causes interference between the reflected light and the incident light, and that blocks transmission at the selected wavelength. They are called "Interference Filter" or "Dichroic Filter."
https://en.wikipedia.org/wiki/Interference_filter
above found with:
https://www.google.com/search?&q=optical+interference+filter+design
Cheers,
Tom
Likes anorlunda
Are the design of these better?
Aww, come on. What is your definition of 'better?' There are always tradeoffs.
The interference filters can block more of a specific wavelength while letting thru others, so you can see what you are doing. But there cost is substantially higher and they are a bit more prone to scratch damage that destroys their filter capability.
If I remember correctly, poly-carbonates block IR very well and are clear, that is the reason a pair of goggles for NIR are not tinted, other than for the higher OD.
1. What is NIR laser light and why do I need goggles for it?
NIR (near-infrared) laser light is a type of laser light that falls within the near-infrared spectrum, which is invisible to the human eye. It is commonly used in various scientific and industrial applications, such as medical procedures, cutting and welding, and communication technology. Goggles are necessary to protect the eyes from potential damage caused by exposure to NIR laser light.
2. What color will NIR laser goggles be?
The color of NIR laser goggles can vary, but they are typically designed with a dark or opaque lens that blocks out the NIR light. The frame of the goggles may be any color, but it is often black to provide a neutral background for the dark lens.
3. Can I use regular sunglasses as NIR laser goggles?
No, regular sunglasses are not suitable for protecting the eyes from NIR laser light. They are designed to block out visible light, but not invisible light in the near-infrared spectrum. Specialized goggles with the appropriate lens material and thickness are necessary for proper protection.
4. How do I know if my goggles are suitable for NIR laser light?
Goggles that are suitable for NIR laser light will have a label or marking indicating the specific wavelength range they are designed to block. Make sure to check the label or ask the manufacturer to ensure that the goggles are suitable for the specific NIR laser you will be working with.
5. Can I use one pair of NIR laser goggles for all types of NIR lasers?
No, different types of NIR lasers may emit light at different wavelengths, so it is important to use goggles that are specifically designed for the wavelength of the laser you are working with. Using the wrong goggles can result in inadequate protection for the eyes.
  • Optics
  • Optics
