Why does spin-spin coupling cause splitting in NMR spectroscopy?
In summary, the chemical shift (Hz) of a particular chemical will vary with B0, but ppm is frequency independent. However, increasing the frequency (or magnetic field) allows for better resolution and shimming, resulting in less blurring in the spectrum. The SNR also increases with B0, leading to better separation of peaks. While it is possible to use a frequency encoded gradient for localizing spectral signals in 3D space, the math becomes more complicated. Additionally, the separation of J-coupled peaks may also increase with B0, potentially due to SNR improvement.
BobP
74
Hi.
I was wondering if you could please help me understand something about NMR spectroscopy (MRS).
I know that the chemical shift (Hz) of a particular chemical will vary with B0. As I understand (although this may be wrong) ppm is frequency independent so the peaks should always be in the same position
There are two things I do not understand though
1) Why does increasing the frequency increase the separation of peaks on a ppm curve if ppm is frequency indepndenant? (my lecturer said it did)
2) When trying to localise the position of a spectral signal in 3D space why can we NOT use a frequency encoded gradient but we can use a slice or phase encoded gradient (I assume this links with the previous question).
Thank you very much
Increasing the frequency (or, more appropriately, the magnetic field) doesn't change the separation of the peaks in ppm, but it does allow for a better resolution (the peaks are narrower).
I don't know about this. Are talking about solid state NMR?
Thanks. Why does resolution increase?
Has it anything to do with a longer FID decay time? If so, how does this happen?
Don't think so. I am talking about acquiring a signal from a specific voxel in the brain, for example, using spectroscopy in a clinical setting. My lecturer said we cannot use frequency gradients but we can use other gradients. His reasoning was that ppm is affected by frequency but clearly it isn't so I am wondering why we cannot use them.thanks
There are two reasons for that. One reason is simply SNR. Since you have higher SNR at higher field strengths two peaks that are blurred out by noise at los field strengths may be separable at higher field.
The second is due to shimming. A poor shim causes blurring in the spectrum. Say you can shim down to 10 Hz at both fields, then that is a smaller ppm blurring at the higher field.
You can, but the math gets substantially more complicated. Andrew Maudsley at University of Miami and Stefan Posse at New Mexico have each developed their own approaches for doing that.
Are you familiar with the k space approach for understanding encoding?
Why does SNR increase with B0? thanks
Sadly not :( Is it possible to explain why it is more complicated without going into it?
As the field strength increases you get more net longitudinal magnetization in the fully relaxed state. I don't remember the numbers exactly, but it is something like 6 excess protons per million at 1.5 T vs 12 excess protons per million at 3.0 T.
Ah of course! thanks
On a slightly unrelated note, I have been told that the separation of J-coupled peaks increases as B0 increases. Please could you suggest why this is, again, as ppm is unrelated to B0
I had to think a bit about this. Basically, what makes the Fourier transform easy is that it is separable. A 2D FFT is just a bunch of 1D FFT in one direction followed by a bunch of 1D FFT in the other direction. But this relies on the data being laid out in a nice rectilinear grid in k space.
But the corresponding "gradient" for spectroscopy is just time, which you cannot turn off or rewind. So if you do spatial encoding and spectroscopic encoding you wind up going diagonally through k space which complicates things.
I think that this is purely due to SNR, but I am more on the imaging side than the spectroscopy side. So I am not certain.
Be careful here. The chemical shift is independent of B0, but the calculation of ppm depends on the operating frequency, as it is basically
\frac{\nu_\mathrm{sample} - \nu_0}{\nu_0} \times 10^6
Since the transition frequency due to the chemical shift (##\nu_\mathrm{sample} - \nu_0##) and the reference frequency have the same variation with respect to B0, the field cancels out and the chemical shift, expressed in ppm, is independent of B0.
However, the J-coupling comes from spin-spin interaction, which is independent of B0. Since it induces a fixed shift in ##\nu_\mathrm{sample}##, in terms of ppm it decreases as B0 increases.:
$$J\ \mathrm{Hz} = \delta\ \mathrm{ppm} \times \nu_0\ \mathrm{MHz}$$
Likes BobP
I see. thanks
thank you. To clarify, did you mean However, the J-coupling comes from spin-spin interaction, which is DEPENDANT on B0.
No. The spin-spin coupling is intrinsic to the molecule, thus is independent of any external field.I've stolen the following at http://orgchem.colorado.edu/Spectroscopy/nmrtheory/splitting.html
http://orgchem.colorado.edu/Spectroscopy/nmrtheory/figures/splittingsum.gif
Likes BobP
thanks
What is NMR spectroscopy?
NMR (nuclear magnetic resonance) spectroscopy is a technique used to study the physical and chemical properties of molecules by observing the behavior of their atomic nuclei in a magnetic field.
How does NMR spectroscopy work?
NMR spectroscopy works by exposing a sample to a strong magnetic field, which causes the atomic nuclei to align. A radiofrequency pulse is then applied, causing the nuclei to absorb energy and flip their spin. When the pulse is turned off, the nuclei return to their original state, releasing energy that can be detected and used to create a spectrum.
What types of information can be obtained from NMR spectroscopy?
NMR spectroscopy can provide information about the chemical structure, molecular dynamics, and physical properties of a sample. It can also be used to determine the concentration and purity of a substance, as well as the presence of impurities or contaminants.
What are the advantages of using NMR spectroscopy?
NMR spectroscopy is a non-destructive and non-invasive technique that does not require the sample to be altered in any way. It can provide highly detailed and quantitative information about a sample, and is widely used in various fields such as chemistry, biochemistry, and medicine.
What are the limitations of NMR spectroscopy?
One limitation of NMR spectroscopy is that it requires specialized equipment and trained personnel. It is also a relatively expensive technique and may not be suitable for analyzing certain types of samples, such as those with low concentrations or complex mixtures.
  • High Energy, Nuclear, Particle Physics
  • Biology and Chemistry Homework Help
  • Electromagnetism
