NMR Spectroscopy: Butane in Magnetic Field & Hydrogen Alignment
In summary: Thus net magnetization (and thus NMR signal) cannot result.In summary, in NMR spectroscopy, when a molecule such as butane is placed in an external magnetic field, the hydrogens align parallel or antiparallel to the direction of the field depending on the temperature. At room temperature, the populations of the two energy levels are nearly equal, resulting in a population distribution of 50-50%. The radio frequency field can only induce transitions between states with the same spin but different spin orientation, and the states with the same spin but different orientation are degenerate, resulting in no NMR signal.
cnidocyte
36
When a molecule, let's say butane is placed in an external magnetic field and its hydrogens align parallel or antiparallel to the direction of the magnetic field, do 50% of the H atoms align parallel to the B field and the other 50% align antiparallel or what? If so, when they radio waves are applied would it only be the 50% of the H atoms that are aligned parallel that would be flipped to a higher energy level and recorded by the spectrometer?
Chemistry news on Phys.org
Can't help you much, but you may want to read about relaxation in NMR spectroscopy.
No, it depends on the temperature.
In a magnetic field, the degeneracy of the two energy level is removed, so one will be higher than the other. The lower energy level (spin parallel to the field) will tend to be more populated than the other. How much the higher state is populated depends on the temperature of the material. This means that as 0K, only the lowest state is populated. At room temperature, a fraction of the higher state is populated. How much it is populated depends on the energy difference and the temperature, i.e. statistics.
Zz.
I wonder - in the case of organic molecules, are they really degenerated before magnetic field is applied? After all, it is a little bit like ortho and para hydrogen - they differ enough to be separated. Sure, hydrogen is a specific case, so the difference can be much more pronounced, but is there any reason for the energy difference to disappear in more complicated molecules?
The magnetic fields applied in NMR are around 10 - 15 T, which is enormously strong compared to spin magnetic fields in molecules. I don't think the molecular structure has any measurable effect on the spin preference of protons. At least I can't find anything about it on Google.
Methane molecule has 3 possible spin orientations - do you think each of them has the same energy? I think not. Could be differences are small enough to be negligible, but at least they should be possible to estimate.
Yes, there exists a "nuclear hyperfine splitting" if the electronic system is paramagnetic. But AFAIK they don't usually need to take it into account in NMR.
Well, what happens is that the nuclear-spin dipole coupling averages out to zero, because the molecules are all moving and rotating relative the magnetic field. But you can indirectly measure it through the Nuclear Overhauser Effect, hence giving you information about the relative locations of the nuclei (since the spin polarization is obviously distance-dependent). This is the basis of structural NMR methods.
To answer the original question: Yes, the populations are very near 50-50% at room temperature; as the energy difference is very small. As you said, the splitting is in the radio-wave region - which region of the spectrum do you associate with heat? (This is a blessing in disguise; at higher energies the NMR signal would likely have been drowned out by thermal noise. As it is, there's relatively little going on in that region of the spectrum) NMR spectrometers are just very sensitive. We're talking about a population distribution of 50.001%-49.999% or around that order.
Borek, yes, even without magnetic field, there are states of different energy. Without a magnetic field, these states can be classified by total Spin S. The radio frequency field cannot induce transitions between states with different S but only between states differing in M_S. However, the states with same S and different M_S are degenerate, so no NMR signal will result. An even more fundamental reason is the time reversal invariance of the Hamiltonian of the system without magnetic field which guarrantees that to every possible transition there exists an equally probable transition in the other direction.
1. What is NMR Spectroscopy and how is it used to study molecules?
NMR (Nuclear Magnetic Resonance) Spectroscopy is a powerful analytical technique used to study the structure and dynamics of molecules. It is based on the principle that certain atomic nuclei, when placed in a strong magnetic field, will absorb and re-emit electromagnetic radiation at specific frequencies. By studying these frequencies, scientists can gain information about the chemical environment and interactions of the nuclei, which can help identify and characterize molecules.
2. What is the significance of studying butane in a magnetic field in NMR Spectroscopy?
Studying butane in a magnetic field allows scientists to observe and analyze the behavior of its hydrogen atoms. The alignment of the hydrogen atoms in the molecule changes in the presence of a magnetic field, which can provide valuable information about the structure and dynamics of the molecule. This is important in understanding the physical and chemical properties of butane, as well as other similar molecules.
3. What are the different types of NMR Spectroscopy and how do they differ?
There are two main types of NMR Spectroscopy: Proton NMR and Carbon NMR. Proton NMR involves studying the behavior of hydrogen atoms in a molecule, while Carbon NMR looks at the behavior of carbon atoms. These two types of NMR spectroscopy provide complementary information about a molecule, and are often used together in chemical analysis.
4. How is NMR Spectroscopy used in organic chemistry?
NMR Spectroscopy is widely used in organic chemistry to determine the structure and composition of organic compounds. By analyzing the signals produced by different nuclei in a molecule, scientists can identify the types of atoms present, their chemical environment, and their connectivity within the molecule. This information is crucial in determining the structure and function of organic compounds.
5. What are some limitations of NMR Spectroscopy?
Although NMR Spectroscopy is a powerful technique, it does have some limitations. For example, it cannot be used to study molecules that do not contain nuclei with magnetic properties, such as noble gases. Additionally, the technique requires a high level of expertise and expensive equipment, which can be a barrier for some researchers. Finally, NMR Spectroscopy only provides information about the average behavior of molecules, and cannot capture any dynamic changes or interactions that occur on a faster timescale.
  • Quantum Physics
  • Atomic and Condensed Matter
  • Electromagnetism
  • Quantum Physics
  • Quantum Physics
