Adding New Section Panel: Do We Need a Separate Feeder & Breaker?
  • Thread starter mohamed sleem
  • Tags
    Section
In summary, the conversation discusses the NEC code's limit of 42 circuits per panel and how to handle the situation when more circuits are needed. The solution proposed is to add a new section panel, but the question arises whether a separate feeder and breaker are necessary for the additional section. It is advised to consult with a professional or local licensing office for specific code requirements and approval.
mohamed sleem
As you all know the NEC code permits only 42 circuits per panel. so what we could do if we need more than 42 circuits ? In order to use more than 42 circuits we can add new section panel. However my question is do we need a separate feeder and breaker for the additional section?
mohamed
Is this an academic question?
If you are doing actual wiring you should not be seeking answers to to these kinds of questions here. For one thing many local codes override NEC codes. We do not even know what country you are in. Your best bet is to hire someone who is familiar with code requirements in your area. Alternatively you can contact your local licensing/permitting office and speak with an inspector. They are generally very helpful, and are the ones who will ultimately be approving the work.
Well said. Thread locked.
1. What is a section panel and what is its purpose?
A section panel, also known as a distribution panel, is an electrical panel that distributes electricity to different areas or circuits within a building. Its purpose is to safely distribute power and protect against overloading circuits.
2. Why might we need a separate feeder and breaker for a new section panel?
A separate feeder and breaker may be necessary for a new section panel if the existing panel is already at maximum capacity and cannot handle the additional load. It is important to ensure that the electrical system is not overloaded, as this can result in safety hazards.
3. How do I determine if a separate feeder and breaker are needed for a new section panel?
You will need to consult with a licensed electrician to determine if a separate feeder and breaker are necessary for a new section panel. They will be able to assess the existing electrical system and determine the best course of action for adding a new section panel.
4. Can a new section panel be connected to the existing feeder and breaker?
In some cases, a new section panel can be connected to the existing feeder and breaker if there is enough capacity to handle the additional load. However, it is important to consult with a licensed electrician to ensure that this is done safely and within code regulations.
5. Are there any safety considerations when adding a new section panel with a separate feeder and breaker?
Yes, there are several safety considerations when adding a new section panel with a separate feeder and breaker. It is important to ensure that the new panel is properly grounded, and that all wiring and connections are done correctly to prevent electrical hazards. It is also important to follow all local building codes and regulations.
  • Electrical Engineering
