Homework Help: Nodal analysis question
  1. Feb 6, 2014 #1
    I understand their method. However, if you use the node to the left of the 2 ohm resistor (the node where the voltage = 75 V) then you get:
    (75-Vx)/2 -10 = 0
    so 75-Vx = 20
    so Vx - 75 = -20
    Vx = 55 V
    But this is not 25 V as it should be?
    When doing nodal analysis, do you have to consider each node?
  3. Feb 6, 2014 #2
    donpacino
    You did not include the current through the 75 v voltage source. your first equation should have been
    (75-Vx)/2 -10 -(i3+0.4*Vx)= 0
    that being said when you do nodal analysis you should only do kcl's at nodes with unknown voltages. you know that the 75v node is 75 v above ground. So try a KCL at nodes Vx and V1
    does that make sense?
  4. Feb 8, 2014 #3
    Ah yes! Thanks a lot mate.
Have something to add?
Draft saved Draft deleted
