Homework Help: Noise level which formula?
  1. Oct 16, 2016 #1
    When the distance to a sound source is doubled, the noise level will be halved. Yes or no?
    2. Relevant equations
    L = 10 lg(I/10-12) or L = 10 lg(I/l0)
    3. The attempt at a solution
    my book used the first formula in another question and it used the second one in this problem. I know how to solve the problem but what I don't know is where 10-12 comes from. Because in the text where my book tries to explain sound they only write the first formula but then when they gave an example of a problem they used the second formula. Which is the real one and when do I use them?
  3. Oct 16, 2016 #2
    kuruman
    The first formula is the same as the second with l0=10-12 W/m2. That's the so called threshold of hearing
    http://hyperphysics.phy-astr.gsu.edu/hbase/sound/intens.html#c3
    Both are real and either one can be used to answer this particular question. For other questions, I would say you should probably use the first one if a specific value for l is given. Here it is not, and it doesn't matter that it's not.
  4. Oct 16, 2016 #3
    If I and I0 are given and I calculate the value of L, what is L giving me? Is it the noise level when the intensity is I or is it the noise level difference from when it goes from I0 to I?
  5. Oct 16, 2016 #4
    kuruman
    It is the sound level in decibels relative to the threshold of hearing. If you read on the hyperphysics link, the threshold of pain is 130 dB. You can solve the equation for I with I0 = 10-12W/m2 and L = 130 dB, to get I = 10 W/m2.
Have something to add?
Draft saved Draft deleted
