Nominal voltage for plasma?
In summary, the lowest voltage required for Helium to become ionized is around 24 electron volts. However, this is different from the breakdown potential, which is typically 50 to 150 volts. Plasma can be formed and sustained at low voltages when there is an electron source, but in cold electrode discharges, a higher voltage is needed to generate electrons from ion impact and sustain the plasma.
CognitiveNet
53
What is the lowest voltage required in order for Helium to become ionized?
Is that equal the ionization energy in electron volt per mole (kJ/mole)?
If so it's only about 24 eV for Helium.
Typical voltages are around a few thousand volts for most commercial plasma globes, sometimes around 10,000 volts for some homebrew ones.
But ionization potential is typically 50 to 150 volts.
So does this mean that the plasma is created at very low voltages but in the case for plasma globes are very high voltages?
You have a misconception about ionization energy (sometimes colloquially referred to as potential) and breakdown potential.
First of all, these two quantities have different dimensions, the first one energy (measured in electron-volts, a unit of energy), and the second one in units of electric voltage/potential (measured in volts). You are essentially comparing apples and oranges.
My appreciation and gratitude for your answer is endless.
There is a connention between ionisation potential and voltage. 24 electron volts is the energy gained by a electron in traveling through a potential difference of 24 Volts. So if you have a voltage gap of 24 volts and an electron travels through this gap then it will gain enough energy to ionise a He atom.
If you have an electron source, like a hot filament and a voltage drop of 24 Volts at low pressure in helium a plasma can be formed and sustained.
In a plasma ball or other cold electrode discharge there is no electron source so electrons are released from the surface by ion impact, also electrons are accelerated in the electric field in the gas. As some of the plasma have high pressures then collisions reduce the average energy of electrons. In this case the plasma needs a field E/N greater than a particular value. Where E in the field Voltage/Gap and N is the neutral gas density. The larger the gap the bigger the voltage needed. The higher the presuure the bigger the voltage needed. So with a cold electrode discharge we need enough voltage between the plasma and a surface to generate electrons from ion impact and a large enough E/N to sustain the plasma is the bulk.
The nominal voltage for plasma generation can vary depending on the gas used and the specific conditions of the plasma system. In the case of Helium, the ionization potential, or the minimum voltage required for ionization to occur, is approximately 24 electron volts per mole (eV/mole) or 24,000 volts per mole (V/mole). This is equivalent to approximately 4.01 x 10^-18 joules per molecule (J/molecule) or 4.01 x 10^-18 kilojoules per mole (kJ/mole).
However, the typical voltages used in commercial plasma globes are much higher, ranging from a few thousand volts to 10,000 volts. This is because plasma globes use a high frequency alternating current (AC) power supply, which can generate much higher voltages than the nominal voltage required for ionization.
It is important to note that the ionization potential is not the only factor that influences the voltage required for plasma generation. Other factors such as gas pressure, temperature, and electrode configuration can also affect the voltage needed to create and sustain a plasma. Therefore, the actual voltage used in a plasma system may vary from the nominal voltage depending on these variables.
1. What is the nominal voltage for plasma?
The nominal voltage for plasma is typically between 100-400 volts, depending on the specific plasma source and operating conditions.
2. How does the nominal voltage affect plasma generation?
The nominal voltage plays a crucial role in plasma generation, as it determines the energy of the electrons in the plasma and directly influences the ionization and excitation processes.
3. Can the nominal voltage for plasma be adjusted?
Yes, the nominal voltage for plasma can be adjusted by changing the power supply settings or using a different gas mixture. However, it is important to note that changing the nominal voltage can also affect other plasma properties.
4. What happens if the nominal voltage for plasma is too high or too low?
If the nominal voltage is too high, the plasma can become unstable and cause damage to the equipment. If it is too low, the plasma may not be able to sustain itself and extinguish.
5. How is the nominal voltage for plasma measured?
The nominal voltage for plasma is typically measured using a high voltage probe or a voltmeter connected to the power supply. It can also be estimated by measuring the plasma current and using the known resistance of the plasma source.
  • Electrical Engineering
  • Electromagnetism
