Non conducting cylinder
  • Thread starter lcam2
lcam2
28
1. Homework Statement
A long, solid, non-conducting cylinder of radius 8 cm has a non-uniform volume density, ρ, that is a function of the radial distance r from the axis of the cylinder. ρ = A*r2 where A is a constant of value 3 μC/m5.
Gauss's law EA = Q/(epsilon)
Q(enclosed)= Pv
Volume of cylinder = 2*(PI)*r*L
Part a can be done using gauss's law, and integrating Q(enclosed)= pv; since the volume density is not constant.
The problem is part b, where the point where I have to calculate the field is outside the Gaussian surface.
Answers and Replies
Doc Al
Mentor
45,412
1,848
That's a puzzling statement, since you put the Gaussian surface wherever you need to in order to find the field. Please state the complete part b question.
lcam2
28
Im sorry i didn't notice it was missing,
(a) What is the magnitude of the electric field 6 cm from the axis of the cylinder?
(b) What is the magnitude of the electric field 10 cm from the axis of the cylinder?
Doc Al
Mentor
45,412
1,848
OK, so what's the problem in applying Gauss's law to solve this part, just like part a?
Hint: Your Gaussian surface will have a radius of 10 cm.
lcam2
28
so, basically what you are saying is that the original radius of the cylinder does not matter, am I correct?
Doc Al
Mentor
45,412
1,848
It matters in that it tells you the extent of the charge distribution. But it doesn't prevent you from having a Gaussian surface outside of the cylinder.
lcam2
28
Ok, thank u!
Suggested for: Non conducting cylinder
10K
15K
  • Last Post
  • Last Post
20K
  • Last Post
  • Last Post
