Homework Help: Non-Conservative Work
  1. Nov 8, 2008 #1
    A 0.620 kg wood block is firmly attached to a spring (k = 180 N/m). It is noted that the block-spring system, when compressed 0.050 m and released, stretches out 0.023 m beyond the equilibrium position before stopping and turning back. what is the coefficient of kinetic friction between the block and the table?
    2. Relevant equations
    -(Wnc) = PEf - PEo + KEf - KEo
    3. The attempt at a solution
    1/2 kx2 = 1/2 mv2 + umgd
    This equation has two unknowns (u and v). I don't know any other equation to solve for the unknowns, so I'm stuck here... What other equation do I use?
  3. Nov 8, 2008 #2
    I would look at the block at the two times it has zero velocity (i.e. before it is released, and just as it changes direction, call these points A and B), and compare the potential energies stored in the spring. Then work done against friction in going from A to B is the difference in potential energies:
    [tex] W = \frac{k}{2}(0.05^2 - 0.023^2) [/tex]
    You know the distance travelled is the distance AB, so using the work calculated in the last line:
    [tex] W = F(0.023 + 0.05)[/tex]
    Then you need to work out the coefficient of friction. First, the reaction force R of the table on the block:
    [tex]R = mg[/tex]
    Then,
    [tex]F = \mu R[/tex]
    I'm not sure whether this is correct.
