1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Non-uniform mass with calculus
  1. Nov 27, 2012 #1
    find the mass of an unevenly distributed bar with length 2 meters whos mass at a point is given by an equation 0.6 + x^2. Then find the center of mass.
    2. Relevant equations
    3. The attempt at a solution
    I got the first part (finding the mass) correctly, but I can't conceptually figure out why what i did to find the center of mass doesn't work.
    integrate to get 0.6x + x^3/3 and evaluate from 0 to 2, to find that the mass is 2 kg.
    What I tried to do to find the center of mass is just set that equation equal to half the mass and solve for X, however this is not correct and I do not know why....
  3. Nov 27, 2012 #2
    The approach you used would be correct if you were trying to find the location where 1/2 the mass is to the left and the other other 1/2 is to the right. :smile:
    But that's not what you're being asked to find. :frown:
    Here, the term "center of mass" needs to take into account the leverage involved. Sometimes the term is also called the barycenter, center of gravity, weighted center or point of balance. You're looking for the point such that if you were to grab the object at that point with your fingers, it would balance.
    I'm guessing that you might find a formula for the barycenter (center of mass) from your textbook. With that, you can simply plug and chug.
    Or you could derive the formula yourself. If you define r as the distance from the barycenter xc to some small mass dm, then you need to set up an equation such that the sum of all r dm on one side of xc equals the sum of all r dm on the other side of xc. Then solve for xc.
    Good luck! :smile:
Similar Threads - uniform mass calculus Date
Center of mass of a uniform wire Jan 17, 2018
Finding the center of mass of an arbitrary uniform triangle Jan 14, 2017
Masses Over a Uniform Cylindrical Pulley Oct 28, 2016
The uniform rod mass m Sep 16, 2016
