Noncoordinate Basis: Explanation and Importance
  • Thread starter matness
  • Tags
    Basis
In summary, non-coordinate bases refer to defining a basis for a vector space without relying on a specific coordinate system. This can be useful for physical interpretation and calculations in general relativity, where spacetime is modeled as a 4-dimensional differentiable manifold. Orthonormal bases can be defined by specifying an array of one-forms, which map the vectors of the tangent space to scalars. This concept has applications in navigation, computer graphics, and determining the topology of spacetime.
matness
90
Can anybody give me an explanation about non coordinate bases and its importance?
All that means is that you are not required to have a coordinate-system in order to define a basis for a vector space. I have seen the phrase "non-coordinate" used in Tensors and always assumed it just meant "coordinate free"- that is the equations themselves did not depend on a particular coordinate system.
Lectures 4 and 5 at http://ocw.mit.edu/OcwWeb/Physics/8-962Spring2002/LectureNotes/index.htm may be enlightening.
The tangent space at each point [itex]p[/itex] of an n-dimensional differentiable manifold is an n-dimensional vector space and thus has an infinite number of bases. If [itex]p[/itex] is contained in a patch covered by the coordinates [itex]\{x^{\mu}\}[/itex], then
[tex]
\{ \frac{\partial}{\partial x^{\mu}}\}
[/tex]
is a coordinate basis for the tangent space. However, not all vectors in the
tangent space are tangent to (any) coordinate curves.
In general relativity, spacetime is modeled by a 4-dimensional differentiable manifold. Coordinate bases are very useful for calculations, but non-coordinate orthonormal bases are useful for physical interpretation.
As an example, consider the Schwarzschild metric
[tex]
\mathbf{g}=\left( 1-\frac{2M}{r}\right) \mathbf{dt}\otimes\mathbf{dt}-\left( 1-\frac{2M}{r}\right) ^{-1}\mathbf{dr}\otimes\mathbf{dr}-r^{2}\left( \sin^{2}\theta\mathbf{d\theta}\otimes\mathbf{d \theta}+\mathbf{d\phi}\otimes\mathbf{d\phi}\right).
[/tex]
An observer hovering at constant [itex]r[/itex], [itex]\theta[/itex], and [itex]\phi[/itex] has orthonormal basis vectors
[tex]
\begin{align*}
\mathbf{e}_{0} & =\left( 1-\frac{2M}{r}\right) ^{-\frac{1}{2}} \frac{\partial}{\partial t}\\
\mathbf{e}_{1} & =\left( 1-\frac{2M}{r}\right) ^{\frac{1}{2}}\frac
{\partial}{\partial r}\\
\mathbf{e}_{2} & =\frac{1}{r\sin\theta}\frac{\partial}{\partial \theta}\\
\mathbf{e}_{3} & =\frac{1}{r}\frac{\partial}{\partial\phi},
\end{align*}
[/tex]
while an observer freely falling from rest at infinity has orthonormal basis
vectors
[tex]
\begin{align*}
\mathbf{e}_{0}^{\prime} & =\left( 1-\frac{2M}{r}\right) ^{-1}\frac
{\partial}{\partial t}-\left( \frac{2M}{r}\right) ^{\frac{1}{2}}\frac{\partial}{\partial r}\\
\mathbf{e}_{1}^{\prime} & =-\left( \frac{2M}{r}\right) ^{\frac{1}{2}
}\left( 1-\frac{2M}{r}\right) ^{-1}\frac{\partial}{\partial t}
+\frac{\partial}{\partial r}\\
\mathbf{e}_{2}^{\prime} & =\frac{1}{r\sin\theta}\frac{\partial}
{\partial\theta}\\
\mathbf{e}_{3}^{\prime} & =\frac{1}{r}\frac{\partial}{\partial\phi}.
\end{align*}
[/tex]
The two orthonormal bases are related by
[tex]
\begin{align*}
\mathbf{e}_{0}^{\prime} & =\left( 1-\frac{2M}{r}\right) ^{-\frac{1}{2}
}\mathbf{e}_{0}-\left( \frac{2M}{r}\right) ^{\frac{1}{2}}\left( 1-\frac
{2M}{r}\right) ^{-\frac{1}{2}}\mathbf{e}_{1}\\
}\left( 1-\frac{2M}{r}\right) ^{\frac{-1}{2}}\mathbf{e}_{0}+\left(
1-\frac{2M}{r}\right) ^{-\frac{1}{2}}\mathbf{e}_{1}\\
\mathbf{e}_{2}^{\prime} & =\mathbf{e}_{2}\\
\mathbf{e}_{3}^{\prime} & =\mathbf{e}_{3}.
\end{align*}
[/tex]
It turns out that the relative velocity between the 2 observers is given by
[tex]
v=-\left( \frac{2M}{r}\right) ^{\frac{1}{2}},
[/tex]
so the relation between the 2 bases is given by the Lorentz transformation
[tex]
\begin{align*}
\mathbf{e}_{0}^{\prime} & =\frac{\mathbf{e}_{0}+v\mathbf{e}_{1}}
{\sqrt{1-v^{2}}}\\
\mathbf{e}_{1}^{\prime} & =\frac{v\mathbf{e}_{0}+\mathbf{e}_{1}}
{\sqrt{1-v^{2}}}.
\end{align*}
[/tex]
Lorentz transformations are useful is general relativity as well as special relativity!
Let's take a very simple example. Suppose you have polar coordinates, r and [itex]\theta[/itex].
Then the tangent space in the coordinate basis given by the vectors [tex]\frac{\partial}{\partial r}[/tex] and [tex]\frac{\partial}{\partial \theta}[/tex]. [1]
The vectors in this tangent space happen to be orthogonal, but not orthonormal. A line element in polar coordinates is [itex]ds^2 = dr^2 + r^2 d \theta^2[/itex], you can see that the metric tensor is not an identity.
Suppose you express the tangent space in terms of orthonormal vectors [itex]\hat{r}[/itex] and [itex]\hat{\theta}[/itex] rather than in terms of the coordinate basis vectors of [1].
The result is very useful for physics. It is always possible to define an orthonormal basis at a point, even if you are unfortunate and have non-orthogonal vectors in the coordinate basis.
Such an orthonormal basis can be defined in general by specifying an array of n one-forms (aka contravariant tensors) that map the vectors of the tangent space to n scalars. These n scalars are the n orthonormal coordinates.
[Definition: a vector is a member of the tangent space, the dual of a vector is a map of a vector to a scalar, this has various names such as "one-form", contravariant vector, etc.]
One usually sees this described as "an orthonormal basis of one-forms".
Note that it is not strictly necessary that a non-coordinate basis be orthonormal, this is just a typical application of the concept.
Weren't one-forms covariant tensors?
Ya, they were and it's Schwarzschild...
Daniel.
Probably <checking>, yes, it appears I got that backwards :-(
In General Relativity, the manifold [tex]M[/tex] is 4-dimensional, so why don;t we simply take [tex]M=\Re^4[/tex] and use much simplier symbols in the differential geometry?:confused: :confused:
The theory itself allows the possibility for 4-manifolds other than R4. Indeed, there are interesting solutions that don't have R4 as the base manifold. An interesting related question is "How can we determine the topology of spacetime?"
In General Relativity, the manifold is 4-dimensional, so why don;t we simply take and use much simplier symbols in the differential geometry?
note that manifold is only required to look locally like R^n, it may look globally different from R^n
Mobius Strip Universe?
So, are there any existing models with M not equals to Re^4, say, for example any theories for the manifold M being a Mobius Strip?
Schwarzschild is R2 x S2.
A Mobius strip is only two-dimensional...but if you cross it with some other 2-d space [to obtain a 4-manifold], it will fail to be either time- or space-orientable...which might be regarded as unphysical.
Hold on, should Schwarzschild be [tex]S^3\times\Re [/tex] instead, for
[tex](r,\theta,\varphi)[/tex] is 3-dimensional spherical plus [tex]t\in\Re[/tex]?
Could we possible think of [tex]M[/tex] being a higher-dimensional Mobius strip or Klein bottle analog? That should be something to do with "worm-holes" in space and we could possible to do "space travel"?:confused:
bchui said:
Hold on, should Schwarzschild be [tex]S^3\times\Re [/tex] instead, for [tex](r,\theta,\varphi)[/tex] is 3-dimensional spherical plus [tex]t\in\Re[/tex]?
[itex] \left\{ r, \theta, \phi \right\}[/itex] is not a coordinate system for [itex]S^3[/itex]. [itex]S^3[/itex] is the 3-dimensional surface of a 4-dimensional ball; [itex]S^3[/itex] is not a 3-dimensional ball.
[itex] \left\{ \theta, \phi \right\}[/itex] is a coordinate system for (most of) [itex]S^2[/itex], the 2-dimensional surface of a 3-dimensional ball. Actually, since [itex]S^2[/itex] is compact, it cannot be covered in its entirety by a single chart.
Regards,
George
:!) You are right, so Schwarzschild is a metric on the manifold
[tex]M=S^2\times {\bf R}^+\times {\bf R}[/tex], for we have [tex]r>0[/tex] and [tex]t\in {\bf R}[/tex]
So, [tex]M[/tex] is actually the domain of the parameter values, not the "actual space" we want to describe? For, the "actual space" we want to describe is [tex]{\bf R}^4[/tex]?:confused:
Does that applies to Robertson-Walker metric and many others?
One has to be a little careful here, but basically yes.
Also, note that [itex]\mathbb{R}[/itex] and [itex]\mathbb{R}^+[/itex] are diffeomophic via [itex]x \mapsto e^x[/itex], so the underlying manifold for Schwarzschild also can be considered to be [itex]M = S^{2} \times \mathbb{R}^{2}[/itex], justs as robphy said.
No, an n-dimensional manifold is that looks locally like [itex]\mathbb{R}^n[/itex], but not necessarily globally. The "actual space" for Schwarzschild is [itex]M[/itex], not [itex]\mathbb{R}^4[/itex].
The open Friedman-Robertson-Walker universes have underlying manifold [itex]\mathbb{R}^4[/itex], while the closed Friedman-Robertson-Walker universes have underlying manifold [itex]\mathbb{R} \times S^{3}[/itex].
Open and closed refer to 3-dimensional spatial hypersurfaces, and closed means compact, i.e., [itex]S^3[/itex] is compact.
Regards,
George
What is a noncoordinate basis?
A noncoordinate basis is a set of vectors that do not have a fixed position in space and are not aligned with a coordinate system. They are usually defined by their direction and magnitude, rather than their specific location.
Why are noncoordinate bases important?
Noncoordinate bases are important because they allow us to describe and analyze physical phenomena that cannot be easily represented using a fixed coordinate system. They are particularly useful in fields such as relativity and quantum mechanics, where the object of study may not have a well-defined position or may exist in multiple locations simultaneously.
How do noncoordinate bases differ from coordinate bases?
The main difference between noncoordinate and coordinate bases is that coordinate bases are fixed and aligned with a coordinate system, while noncoordinate bases are not. This means that the components of vectors in a noncoordinate basis can change depending on the orientation and position of the basis, while the components of vectors in a coordinate basis are constant.
What are some examples of noncoordinate bases?
Examples of noncoordinate bases include the spherical and cylindrical coordinate systems, which are commonly used to describe physical phenomena with rotational symmetry. Other examples include the spin basis used in quantum mechanics, and the tangent space basis used in differential geometry.
How are noncoordinate bases used in scientific research?
Noncoordinate bases are used in scientific research to describe and analyze physical phenomena that cannot be easily represented using a fixed coordinate system. They allow scientists to better understand and model complex systems, and are particularly important in fields such as physics, astronomy, and engineering.
  • Linear and Abstract Algebra
  • Differential Geometry
  • MATLAB, Maple, Mathematica, LaTeX
