Normal force changes
  • Thread starter Tokspor
Tokspor
Hi guys, I am confused about how the normal force exerted on an object changes depending on the situation.
Let's say an object weighs 10 N at rest. The normal force here is 10 N as well since that is by how much the object is pushing down on the surface.
When someone tries to pull it upward with a 6 N force, it "relieves" some of the normal force. Since the object is now only pushing down on the surface with 4 N, the normal force is 4 N.
So the proper set-up for an equation here is F(normal) = F(gravity) - F(upward)
But in an elevator, let's say the elevator is accelerating upward at 2 m/s^2. If a person were inside the elevator, why doesn't this "relieve" some of their normal force as well? Instead, I have been told that the proper equation for this situation is F(upward) = F(normal) - F(gravity). Rearranging that equation, F(normal) = F(upward) + F(gravity). So now the normal force is actually much greater as a result of an upward force.
Why is this so?
Answers and Replies
cragar
2,552
action- reaction , if the elevator is accelerating upward this adds to the force , like you would feel heavier going up. And in relativity there is no difference between being accelerated by a rocket or being in a gravitational field .
tiny-tim
25,836
255
Welcome to PF!
Hi Tokspor! Welcome to PF! :smile:
(try using the X2 tag just above the Reply box :wink:)
… So the proper set-up for an equation here is F(normal) = F(gravity) - F(upward)
Why is this so?
Because you're using "F(upward)" to mean two different things
in the first case, it's a separate (third) applied force, but in the second case it's the total of the (two) forces. :wink:
Let's apply good ol' Newton's second law …
in the first case, a = 0, and so all the forces must add to 0 …
F(normal) + F(gravity) + F(applied) = 0,
ie F(normal) = mg - F(applied),​
('cos gravity is downward :wink:)
but in the second case, a = 2,
F(normal) + F(gravity) = 2,
ie F(normal) = mg + 2,​
… see? no applied force!! :biggrin:
Doc Al
Mentor
45,410
1,845
The proper set-up in both cases is to use Newton's 2nd law:
ΣF = ma
F(normal) - F(gravity) = ma
When the acceleration is zero, the normal force equals your weight. If the elevator is accelerating upward (thus a > 0), the normal force is greater than your weight--you feel heavier. (The normal force must not only support your weight but accelerate you.)
Edit: While I was goofing off, tiny-tim beat me to it! :cool:
sganesh88
289
This is because in this elevator scenario, the normal force is the source of this "upward force" too. If suppose a huge guy infront holds you by your neck and lifts you, the "upward force" is provided by *his* hands. In that case, the normal force gets some help and is relieved as you hoped. (Also hope he releases you soon.)
Suggested for: Normal force changes
  • Last Post
17K
  • Last Post
  • Last Post
  • Last Post
13K
  • Last Post
  • Last Post
17K
  • Last Post
  • Last Post
  • Last Post
