Normal Force on Sliding Ladder
In summary: So, I imagine the problem would be a little simpler if I could assume that the ladder is static at the bottom.
Quantum1990
A ladder of length l and mass m leans against the side of a house, making an angle θ with the vertical. Assume that the ladder is free to slide at the point where it touches the side of the house (there is no significant friction). Find an expression for the normal force that the side of the house exerts on that end of the ladder in terms of m,g,l,θ
Ʃτ = Iα
ƩF = ma
First, I thought the problem was static(it is in a statics chapter), but with no friction force, I don't think the ladder can be static. Calling the desired normal force N1, and the normal force at the ground N2, I set up the following equations:
max = N1
may = mg-N2
ax = -tanθ ay
I arrived at the third equation using the constraint of a fixed length of the ladder. My problem is using torque( which I think I need). If I sum the torques about the CM, how do I relate angular acceleration(and what angle would I even be measuring) to ax and ay? I believe with this step, I can complete the problem.
There will be static friction at the bottom end of the ladder. Try setting up the torques/moments acting on the ladder about the bottom end.
Are we allowed to assume that there is friction at the ground (or is this required for the problem to make sense)? And will mu not be required?
Yes, there must be friction, otherwise the ladder would slip, but it won't have a moment if you take torques about this end.
But can I set the torques to zero, or am I solving for angular acceleration? Maybe my physical picture is off, but I imagine both ends of the ladder moving(how can only one end move?), so there is a net torque and force. This would make the problem much more complicated.
I just got it. Thanks for your patience. I thought the problem said the ladder was sliding, rather than having the potential to slide.
1. What is normal force on a sliding ladder?
The normal force on a sliding ladder is the perpendicular force exerted by the surface the ladder is resting on. It is equal in magnitude and opposite in direction to the force of gravity acting on the ladder.
2. Why is normal force important in the context of a sliding ladder?
Normal force is important because it is responsible for keeping the ladder in equilibrium and preventing it from slipping or falling. It also helps distribute the weight of the ladder and the person on it evenly, ensuring stability.
3. How is the normal force calculated on a sliding ladder?
The normal force can be calculated using the formula FN = mg cosθ, where FN is the normal force, m is the mass of the ladder and person, g is the acceleration due to gravity, and θ is the angle between the ladder and the horizontal surface.
4. Does the normal force change as the ladder slides?
Yes, the normal force changes as the ladder slides. As the angle between the ladder and the horizontal surface changes, the normal force also changes to maintain equilibrium. When the ladder is at an angle of 90 degrees (vertical), the normal force becomes equal to the weight of the ladder and person.
5. How does the normal force affect the friction force on a sliding ladder?
The normal force affects the friction force on a sliding ladder by increasing or decreasing it. Friction force is directly proportional to the normal force, meaning that as the normal force increases, the friction force also increases. This helps to prevent the ladder from sliding or slipping on the surface.
