Homework Help: Normal Force
  1. Sep 22, 2009 #1
    A 3.72 kg block located on a horizontal floor is pulled by a cord that exerts a force F = 11.5 N at an angle θ = 20.5° above the horizontal. The coefficient of kinetic friction between the block and the floor is 0.070. What is the speed of the block 6.10 s after it starts moving?
    2. Relevant equations
    F=ma
    vf = at
    3. The attempt at a solution
    What is the normal force in this case, because it's not mg, as I tried that and got it wrong.
  3. Sep 22, 2009 #2
    tiny-tim
    Hi Zhalfirin88! :smile:
    That's right … in this case, there are three forces with a (non-zero) component in the vertical direction: F N and W, instead of the usual 2.
    Obviously, you need the three components to add to zero. :wink:
  4. Sep 22, 2009 #3
    Doc Al
    Staff: Mentor
    To figure out the normal force, add up all the vertical force components. What must they add up to?
  5. Sep 22, 2009 #4
    I have no idea what you said after there are 3 non-zero components in the vertical direction.
    Since it's not moving in the vertical direction it'd be zero right?
  6. Sep 22, 2009 #5
    tiny-tim
    There's the force from the cord (F), the weight of the block, and the normal force.
    Their components (in any direction) have to add to zero.
  7. Sep 22, 2009 #6
    Okay, I have no patience for this.
    0 = FN + Fg + FT
    FN = -mg - FT
    FN = -(3.72)(9.8) - 11.5sin(20.5)
    FN = -36.45 - 3.8523
    FN = -40.30 N
    But, you plug that in to static friction equation and you get fs = -2.821
    So, 11.5sin(20.5) + 2.821 = 6.8484N/3.72 kg
    a = 1.841 m/s2
    vf = at
    vf = 1.841 * 6.1
    vf = 11.23 and that is wrong.
    edit: I also did:
    FN = +36.45 - 3.8523 Because down is the negative direction.
    FN = 32.5977 N
    But, you plug that in to static friction equation and you get fs = 2.821
    So, 11.5sin(20.5) - 2.821 = 1.7455N/3.72 kg
    a = .4692 m/s2
    vf = at
    vf =.4692 * 6.1
    vf = 2.86 and that is wrong. But that was my final try at the question so it's wrong for good now.
  8. Sep 22, 2009 #7
    Doc Al
    Staff: Mentor
    You made your mistake in your 2nd line.
    ΣF = FN + Fg + FT
    ΣF = FN - mg + 11.5sin(20.5)
    Since gravity acts down it gets a negative sign, while FT gets a positive sign.
    Since ΣF = 0:
    FN = mg - 11.5sin(20.5)
Loading...
