Proving H is Normal: Let G be an Arbitrary Group
In summary, H is a normal subgroup of group G if and only if for all a,b in G, ab is in H if and only if ba is in H. This is true for all subgroups of G and can be proven by using the definition of normal and showing that both directions hold.
sam09
Hi, I need some help with this problem:
Let H be a subgroup of an arbitary group G. Prove H is normal iff it has the following property: For all a,b, in G, ab is in H iff ab is in H.
Are you sure this is the exact question? Did you notice that this is actually true for all subgroups of G, and is equivalent to saying c is in H if and only if c is in H?
Re
oops, I meant to write for all a,b in G, ab is in H iff ba is in H.
It is a prerequisite of the forums that you say what you're trying to do to solve the problem. Start with the definition of normal.
I'll do half of the proof the other is the same, but with the letters reversed.
if ab is an element of H and H is a normal group then
abab = h for some h element of H
ba = (a^-1)h(b^-1)
gbag^-1 = g(a^-1)h(b^-1)g^-1 for any element g of Ggbag^-1 = g(a^-1)(abb^-1a^-1)h(b^-1)g^-1
but since ab is an element of H so is b^-1a^-1 since H is a group
so
gbag^-1 = (gb)h'(gb)^-1 for h' = b^-1a^-1h which is also an element of H
now by definition of a normal group (gb)h'(gb)^-1 = h'' for some element of H
Therefore gbag^-1 = h'' some element of H
That completes one direction the other direction can be done by the same method.
1. What does it mean for a subgroup H to be normal in a group G?
A subgroup H is normal in a group G if and only if for every element g in G, the conjugate of H by g, denoted by gHg^-1, is also a subset of H. In other words, the left and right cosets of H in G are equal, indicating that H is preserved under conjugation by elements in G.
2. How do you prove that H is normal in G?
To prove that H is normal in G, you must show that for every element g in G, the conjugate of H by g, gHg^-1, is a subset of H. This can be done by either directly showing that gHg^-1 is a subset of H, or by using the definition of normality and showing that gHg^-1 is equal to H.
3. Can a normal subgroup be a proper subset of the group it is normal in?
Yes, a normal subgroup can be a proper subset of the group it is normal in. This means that there are elements in the group that are not in the normal subgroup, but the normal subgroup is still preserved under conjugation by these elements.
4. What is the significance of proving that H is normal in G?
Proving that H is normal in G is significant because it allows us to define the factor group G/H, which is a new group formed by the left cosets of H in G. This factor group has important applications in group theory, including in the study of group homomorphisms and quotient groups.
5. Are there other ways to prove that H is normal in G besides using the definition?
Yes, there are other ways to prove that H is normal in G. Some common methods include using the normal subgroup test, which states that if H is a subgroup of G and for every element g in G, gHg^-1 is a subset of H, then H is normal in G. Another method is to use the properties of normal subgroups, such as the fact that the intersection of normal subgroups is also normal, to show that H is normal in G.
  • Linear and Abstract Algebra
