Proving Normal Subgroup of Abelian Groups
In summary, a normal subgroup of an abelian group is a subgroup that remains unchanged when the elements of the group are multiplied by any element in the group. To prove normality, it must be shown that for any element in the subgroup and any element in the group, the element's conjugate is also in the subgroup. A subgroup cannot be both normal and non-normal. Proving normality allows for a better understanding of the group's structure and behavior. Alternative methods for proving normality include using the first isomorphism theorem or showing that the subgroup is a kernel of a homomorphism. However, the most direct and commonly used method is to show that the subgroup is invariant under conjugation.
fk378
367
Let G be a group and let H,K be subgroups of G.
Assume that H and K are Abelian. Let L=(H-union-K) be the subgroup of G generated by the set H-union-K. Show that H-intersect-K is a normal subgroup of L.
How do i start this?
Start by understanding the definition of L. Then it should be pretty obvious that H[itex]\cap[/itex]K is central in L.
1. What is a normal subgroup of an abelian group?
A normal subgroup of an abelian group is a subgroup that is invariant under conjugation by any element of the group. In other words, if a subgroup is normal, then it remains unchanged when the elements of the group are multiplied by any element in the group.
2. How do you prove that a subgroup is normal in an abelian group?
To prove that a subgroup is normal in an abelian group, you must show that for any element in the subgroup and any element in the group, the element's conjugate is also in the subgroup. This can be done by using the definition of a normal subgroup and the properties of an abelian group.
3. Can a subgroup of an abelian group be both normal and non-normal?
No, a subgroup of an abelian group cannot be both normal and non-normal. If a subgroup is normal, then it must be invariant under conjugation by any element of the group. If it is not normal, then there exists at least one element in the group whose conjugate is not in the subgroup.
4. What is the significance of proving that a subgroup is normal in an abelian group?
Proving that a subgroup is normal in an abelian group allows us to better understand the structure and behavior of the group. It also allows us to make certain conclusions about the group based on the properties of normal subgroups, such as the quotient group theorem.
5. Are there any alternative methods for proving normality of subgroups in abelian groups?
Yes, there are other methods for proving normality of subgroups in abelian groups, such as using the first isomorphism theorem or showing that the subgroup is a kernel of a homomorphism. However, the most direct and commonly used method is to show that the subgroup is invariant under conjugation.
