Subgroup K Normal in Dn: Proof and Examples
In summary, the conversation discusses showing that every subgroup K of <a> is normal in Dn, where Dn is defined as {1,a,...an-1, b, ba,...ban-1} with |a|=n, |b|=2, and aba = b. It is shown that <a> is normal in Dn by the index 2 theorem, and since <a> is cyclic, K is also cyclic and abelian. It is then argued that K is normal in Dn by showing that for any k in K, x in G, and 1 in G, k = x(kx-1), implying that K is a normal subgroup of G = Dn.
hsong9
80
Let Dn = {1,a,..an-1, b, ba,...ban-1} with |a|=n, |b|=2,
and aba = b.
show that every subgroup K of <a> is normal in Dn.
First, we show <a> is normal in Dn.
<a> = {1,a,...an-1} has index 2 in Dn and so is normal
by Thm (If H is a subgroup of index 2 in G, then H is normal in G.)
Next, Since <a> is cyclic, K is also cyclic and abelian.
Let k in K, x in G and 1 in G. ( G = Dn)
k = 1k = (xx-1)k = x(kx-1) because K is abelian.
k in K => xkx-1 in K for all x in G
=> K is a normal in G = Dn.
are you sure the relation isn't meant to be [itex]aba^{-1}=b[/itex]?
also i think it suffices to show that you have an index of 2 OR that for [itex]n \in N, \forall g \in G, gng^{-1} \in N[/itex] in order to imply [itex]N \triangleleft G[/itex].
This doesn't follow. K is abelian, so elements of K commute with themselves; they do not commute with arbitrary elements of G. But then they do not need to - you're trying to show that K is normal, not central.
1. What does "Subgroup K Normal in Dn" mean?
The phrase "Subgroup K Normal in Dn" refers to a specific type of subgroup in the mathematical group Dn. A subgroup is considered normal if it remains unchanged under conjugation by any element in the larger group. In this case, K is the specific subgroup that is being referred to as normal in Dn.
2. What is the significance of Subgroup K being normal in Dn?
When a subgroup is normal in a group, it allows for certain simplifications in calculations and proofs. It also provides insight into the structure and properties of the larger group. In the case of Dn, understanding the normal subgroups can help in classifying and studying the symmetries of regular polygons.
3. How is the normality of Subgroup K in Dn proven?
The proof of Subgroup K's normality in Dn typically involves showing that for any element in Dn, the conjugation of K by that element results in K itself. This can be done using the definition of normal subgroups and the properties of Dn.
4. Can you provide an example of Subgroup K being normal in Dn?
Yes, one example is when K is the subgroup of rotations in Dn. In this case, K is normal in Dn because rotating a regular polygon by any angle does not change its shape or result in a different rotation group.
5. How does the concept of Subgroup K Normal in Dn relate to other mathematical concepts?
The idea of normal subgroups can be extended to other mathematical structures, such as rings and vector spaces. In these cases, the concept of normality can help in understanding the structure and properties of these structures, similar to how it applies in the study of groups like Dn.
