Finding Normal and Tangent Vectors for a 3D Space Curve
In summary, in order to find the normal and tangent vectors at any location along a curve traced by a 3d vector function, we need to find the first derivative of the function. The tangent vector is the first derivative, while the normal vector is the derivative of the unit tangent vector with respect to t. This can be calculated by breaking the function into dimensions and finding the derivative of each component.
adoado
72
Hello all,
Given a 3d vector function f(t) that traces out a path in space, how can I find the normal and tangent vectors at any location along the curve?
Cheers,
Adrian
Well, for us to have a tangent at [itex]P(x(t_1), y(t_1), z(t_1) )[/itex] , the direction the tangent should be pointing in the same direction as the point P is "going" right at that instant when t= t_1. We could break it into dimensions and think about how fast P is going in just the x-direction, how fast it's going in the y-direction and how fast in the z-direction. How could we figure that out?
Right, so it would be the first derivative, or f'(t). But the normal?
Well there's no first derivative, you have a parametrically defined function of 3 variables. So in the x direction, its x'(t), then in y, y'(t) and in z axis, z'(t).
For the normal, I'm not sure. How would you define the normal vector in this case? Normally its the vector perpendicular to the Tangent, but we get a whole Plane that has that for this case.
If [itex]\vec{f}(t)= u(t)\vec{i}+ v(t)\vec{j}+ w(t)\vec{k}[/itex], then a tangent vector is given by [itex]\vec{f}'(t)= u'(t)\vec{i}= v'(t)\vec{j}+ w'(t)\vec{k}[/itex]. The unit tangent vector is that vector divided by its length and the normal vector is the derivative of the unit tangent vector with respect to t.
1. What is a normal/tangent to a space curve?
A normal/tangent is a line that is perpendicular/tangent to a point on a space curve. It represents the direction in which the curve is changing at that specific point.
2. How is the normal/tangent calculated for a space curve?
The normal/tangent can be calculated using the first and second derivatives of the space curve. The first derivative represents the slope of the tangent line, while the second derivative represents the curvature of the curve at that point.
3. What is the significance of the normal/tangent in calculus?
The normal/tangent plays a crucial role in determining the rate of change of a space curve. It is also used in finding the maximum and minimum values of a curve, as well as in calculating the arc length of a curve.
4. Can the normal/tangent be negative?
Yes, the normal/tangent can be negative. This indicates that the curve is changing direction in a clockwise direction at that specific point.
5. How is the normal/tangent used in real life?
The normal/tangent is used in various fields such as engineering, physics, and computer graphics. It helps in modeling and analyzing the motion of objects, designing structures, and creating realistic 3D images.
  • Calculus
  • Calculus
  • Differential Geometry
