• Support PF! Buy your school textbooks, materials and every day products Here!
Normal to parabola
  • Thread starter erisedk
If the normal to the parabola y^2 = 4ax at the point (at^2 , 2at) cuts the parabola again at (aT^2, 2aT), then minimum value of T^2 is
ans: 8
I got the answer but I don't know why it should be the answero_O?
Equation of normal to the parabola in parametric form can be written as
y-2at = -t(x-at^2)
So, in the above equation, I substituted (aT^2, 2aT) as this point will lie on the normal.
2aT - 2at = -t(aT^2 - at^2)
On simplifying,
t^2 + tT + 2 = 0
From here on, I don't quite understand why what I did works.
Minimum value of this quadratic will be at (-b/2a, f(-b/2a) ).
i.e., (-T/2, f(-T/2) )
f(-T/2)= (- T^2 / 4 ) + 2
I equate ( -T^2 / 4 ) + 2 to 0.
I get T^2 = 8.
What did I just do?
Answers and Replies
HallsofIvy
41,833
956
ans: 8
y-2at = -t(x-at^2)
You can write this as 2a(T- t)= -at(T- t)(T+ t)
T- t= 0 only when T= t so NOT another point of intersection. Since T- t is not 0, we can divide by a(T- t) to get
2= -t(T+ t) or t^2+ Tt+ 2= 0.
On simplifying,
t^2 + tT + 2 = 0
Complete the square: t^2+ Tt + 2= t^2+ Tt+ T^2/4- T^2/4+ 2= (t+ T/2)^2- (T^2/4-2).. Since a square is never negative, this will be minimum when t+ T/2= 0 or t= -T/2. In that case, the equation becomes -(T^2/4- 2)= 0 so that T^2/4= 2, T^2= 8.
I get T^2 = 8.
What did I just do?
t^2+ Tt + 2 is just a relation between two points. Why does minimising it work? For ex: If I had the function f(x)=x^2 + 3x + 10 , and I was asked to find its minimum value, I would do what you did above, figure out the minima. This gives me the least value of a certain CURVE, in this case, of a parabola. How does finding the minimum value of t^2+ Tt + 2 give me the minimum value of T^2 ? Just tell me WHY it works, I get how you did it, which is also basically what I did.
RUber
1,687
344
t^2+ Tt + 2 =0 is the conclusion you have come to in order to satisfy the information you were given (i.e. the point is on the normal).
The question asked for the minimum value of T. You could read that as the minimum value of T for which the quadratic has real roots.
i.e. ##\sqrt{T^2 -8} \geq 0##.
Related Threads on Normal to parabola
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
