1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Normalizing a wave function
  1. Mar 31, 2013 #1
    Normalize the wave function
    ψ(x,0) = C1/4 * ea(x2)-ikx a and k are positive real constants
    2. Relevant equations
    ∫|ψ|2dx = 1
    3. The attempt at a solution
    Now, my maths is a little weak, so I'm struggling a little bit here.
    The constant is easy to deal with in all aspects of this problem, so that doesn't worry me, and I've ignored that below to make it easier to read.
    When I'm squaring the e function, do I just square it or do I multiply by its complement?
    If I use complements, the i bit goes away leaving e-2ax2.
    If I square, I get e-2ax2-2ikx This can then be rewritten in the form of cos and sin which allows me to say that the sin function is odd so its integral is 0 and can be ignored (removing the imaginary part again), but it still leaves me with e-2ax2cos(2kx)
    The question goes on to say that I should change the variable of integration and use a standard integral, and I can't see a standard integral looking like either of my avenues that I've pursued above.
  3. Mar 31, 2013 #2
    jtbell
    Staff: Mentor
    By definition, ##|\Psi|^2 = \Psi^*\Psi##. That is, the complex conjugate of ##\Psi## times ##\Psi## itself.
    Speak the magic words "Gaussian integral" to Google and you will find what you're looking for. :smile:
  4. Mar 31, 2013 #3
    If I just had the e-2ax2 term, I can see I would need to use the identity
    ∫e-x2 dx = pi
    But I dont know how to change that given this term is multiplied by cos(2kx) in my problem
    I cant find any gaussian integral that relates e and cos.
    Im sure its just a manipulation problem but Im not too good at manipulating integrals and this is where Im finding myself stuck since Im not entirely sure how to go about it.
  5. Mar 31, 2013 #4
    atyy
    By "complement" do you mean "complex conjugate", in which "i" is replaced by "-i"?
  6. Mar 31, 2013 #5
    Yes. In this case we replace the (-i) with i which when squared and ignoring the constant ends up giving me e-2ax2cos(2kx) ?
  7. Mar 31, 2013 #6
    atyy
    Don't square it - multiply it with the original expression.
    In quantum mechanics, the "squaring" notation means to multiply an expression with its "complement" or "complex conjugate".
  8. Mar 31, 2013 #7
    ψ(x,0) = C1/4 * eax2-ikx a and k are +ve real constants
    So C1/4 * e-ax2-ikx
    = C1/2 * e-ax2-ikx * e-ax2+ikx
    = C1/2 * e-2ax2
    Now ∫e-2ax2 dx = [1/√(2a)]pi using the gaussian integral here
    The constant was (2a/pi) so the whole thing becomes
    √(2a/pi) * √(1/2a) * pi
    The √2a cancels and we're left with pi/√pi which is √pi
    Is this sufficient to prove the wave function is normalized? The answer is finite but is not 1. You can make it 1 by multiplying by 1/√pi or does this mean Ive made an error somewhere?
  9. Mar 31, 2013 #8
    atyy
    I'm terrible at algebra, but shouldn't the Gaussian integral be √(pi/(2a))?
  10. Mar 31, 2013 #9
    Absolutely. Id forgotten that it was √pi and not merely pi
    Carrying this through gives √pi/√pi which is 1 as required!
    Thank you for the help, I feel I understand where I was going wrong much better now.
  11. Mar 31, 2013 #10
    atyy
    I was about to say just normalize it, then I saw they'd chosen a nice value for C.
  12. Mar 31, 2013 #11
    How do I go about manipulating gaussian (standard) integrals?
    From this question I can say that
    ∫e-2ax2 dx = √(pi/2a)
    I have a follow on question that, after doing some manipulation, means I need to find
    ∫x2e-2ax2 dx
  13. Mar 31, 2013 #12
    FWIW, looking here gives me a lot of help and I think that
    ∫x2e-2ax2 dx = 1/2 * √[pi/(2a)^3]
    Its 1/2 and not 1/4 because the standard integral on wiki goes from 0 to inf and we need the area from -inf to inf. Since Im dealing with an even function I can just double the area.
    Grateful though I am for wiki giving me the answer, the question only mentions the standard integral of e-2ax2 so there must be a way of getting to the standard integral for ∫x2e-2ax2 dx that doesnt require the need for searching.
  14. Mar 31, 2013 #13
    atyy
    I think a standard trick is to differentiate with respect to "a" .
    BTW, is this a homework question?
  15. Mar 31, 2013 #14
    jtbell
    Staff: Mentor
    Try the "See Also" links at the bottom of the Wikipedia page.
  16. Mar 31, 2013 #15
    jtbell
    Staff: Mentor
    You left out the C at the beginning of your original expression for ##\Psi##. Usually, when we say, "normalize this wave function", there's an arbitrary constant in front (your C), and you want to find the value of C that makes the whole thing normalized.
    At least, I assume your C is arbitrary. Does your source specify its value to begin with?
  17. Mar 31, 2013 #16
    Awesome. Will do, Thanks.
    Its a set question, but one that doesn't impact upon my grade at all.
  18. Mar 31, 2013 #17
    jtbell
    Staff: Mentor
  19. Mar 31, 2013 #18
    micromass
    Staff Emeritus
    Education Advisor
    2016 Award
    OK, but such questions should be asked in the homework forum. I'll move it for you.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Normalizing a wave function
Loading...
