Why do we use normalization twice in quantum mechanics?
  • Thread starter fuserofworlds
  • Tags
    Wavefunction
In summary, D.J. Griffiths found that the time-independent solution to the infinite square well is Asin(kx), where the constant A is determined by normalization. Once this is done, c_n gives the probability without any further normalization.
fuserofworlds
I was reviewing the infinite square well, using D.J. Griffiths, and came across this small point of confusion. The time-independent solution is shown to be Asin(kx), where the constant A is determined by normalization. Then, in assembling the complete (time dependent) solution, he writes that the most general solution "is a linear combination of stationary states", where each stationary state is assigned a coefficient c_n. Griffiths then explains that |c_n|^2 is the probability of observing that state, and "the sum of all these probabilities should be 1."
My confusion is this: if c_n is the probability of observing each state, why do we use the normalization requirement to find A? Isn't this in effect normalizing twice?
You only normalize once to find A. Once that's done, c_n gives the probability without any further normalization.
Thank you, that makes sense!
It is quiet convenient to work in orthonormal set of basis. Therefore you must normalize each element of basis set such that
[tex]
\int_0^l f_n(x)f_m(x)\,dx = \delta_{n m}
[/tex]
where [itex] f_n(x) = A_n\sin(n\pi x/l)[/itex].
The total statefunction (wavefunction) can be written as a linear combination of the elements of basis set.
[tex]
\Psi(x,t) = \sum_{n=0}^\infty c_n(t)f_n(x).
[/tex]
Now quantum mechanics says the total probability probability should always be unity, so
[tex]
\int_0^l \Psi(x,t)\Psi(x,t)\,dx = 1,
[/tex]
which implies
[tex]
\sum_{n=0}^\infty c_n^2 = 1.
[/tex]
(note: I have assumed real valued wave functions. For complex case, replace with complex conjugate wherever necessary)
[EDIT:]
Normalisation of the basis set just makes the mathematics easy (it is not a necessary requirement), but the normalisation of total statefunction is a constraint of quantum mechanics)
1. What is a wavefunction?
A wavefunction is a mathematical representation of the quantum state of a system. It describes the probability of finding a particle in a specific location and with a specific energy.
2. What does it mean to normalize a wavefunction?
Normalizing a wavefunction means to adjust its amplitude so that the total probability of finding a particle in all possible locations is equal to 1. This ensures that the wavefunction is a valid representation of the quantum state.
3. Why is it important to normalize a wavefunction?
Normalizing a wavefunction is important because it ensures that the total probability of finding a particle in all possible locations is 100%, which is a fundamental principle of quantum mechanics. It also allows for accurate predictions of the behavior of a system.
4. How is a wavefunction normalized?
A wavefunction is normalized by dividing each amplitude by the square root of the total probability. This is known as the normalization constant and it ensures that the total probability of the wavefunction is equal to 1.
5. What happens if a wavefunction is not normalized?
If a wavefunction is not normalized, it means that the total probability of finding a particle in all possible locations is not equal to 1. This can lead to incorrect predictions and is not a valid representation of the quantum state.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
