1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Normalizing a Wavefunction
  1. May 15, 2015 #1
    A particle is described by the wavefunction:
    [tex]\psi (x) = \{ \begin{array}{*{20}{c}}
    {A\cos (\frac{{2\pi x}}{L}){\quad\rm{for }} - \frac{L}{4} \le x \le \frac{L}{4}}\\
    {0{\quad\rm{otherwise }}}
    (a) Determine the normalization constant A
    (b) What is the probability that the particle will be found between x=0 and x=L/8 if a measurement is made?
    2. Relevant equations
    3. The attempt at a solution
    Okay, just verify my logic for me:
    (a) We integrate the wave function from -L/4→L/4, where the particle has a 100% chance of appearing, and set this integral equal to 1 (for the probability just mentioned):
    [tex]1 = \int\limits_{ - \frac{L}{4}}^{\frac{L}{4}} \psi {(x)^*}\psi (x)dx[/tex]
    Integrating this (using Mathematica) and solving for A seems to point at [itex]A = \pm \frac{2}{{\sqrt L }}[/itex].
    I'll only assume the positive value is valid since I'm not sure we can have a negative probability.
    (b) Assuming that the normalization constant in part (a) is correct, we use our new normalization constant in our wavefunction and perform the same integration, this time over 0→L/8. Performing this operation seems to yield 40.9% (0.409).
  3. May 15, 2015 #2
    Yes your logic is correct. You're right that we can't have a negative probability, but since the probability comes from ##\psi ^*\psi##, the normalisation constant only ever appears as ##A^2##, so it doesn't matter whether you pick the positive or negative value. Generally we pick the positive one just because positive numbers are easier to think about.
Have something to add?
Draft saved Draft deleted
Similar Threads - Normalizing Wavefunction Date
Normalize Hydrogen Wavefunction Feb 28, 2017
Normalizing a wavefunction Jan 30, 2016
Normalizing wavefunction Sep 12, 2015
Normalising wavefunctions Feb 21, 2015
Normalize the wavefunction ? Sep 25, 2014
