Find Norton Equiv. for Homework: V=IR
In summary: Thevenin voltage will be dependent on original voltage source and resistance combinations "seen" by the original voltage source. You convert this circuit into Thevenin equivalent. It doesn't affect the load.Another method to find Thevenin resistance is as follows:Short the a-b path and calculate total current (with original voltage source). This is your Norton current(IN). Find Vth using voltage divider.Rth=Vth/IN.=Voc/IscThis method is commonly used when there are dependent...
Marcin H
306
Find the Norton equivalent at the terminals.
V=IR
I did the thevenin equivalent, but I'm not sure where to go from there. How do I get the Norton equivalent out of this? [/B]
Once you've gone to the trouble of determining the Thévenin equivalent, and are sure its correct, there is no need to repeat the process to determine the Norton. The impedance is the same for each, so simply short-circuit your Thévenin equivalent and that gives you the Norton's current.
Though before you calculate the Norton you'd best take another look at your Thévenin, as you have taken invalid shortcuts there. What became of the 20 and 80 ohm resistors?
I just learned this and it's still a bit confusing. Can't I just V=IR and, using the current and resistor, make the 2 sections into voltage sources? Or do I have to add those resistors in series in my thevenin circuit?
You can replace any current source + parallel resistor with a voltage source + series resistor.
Once you have done that, draw your new circuit.
This might help.
So would I just add a 100ohm resistor in series with my picture on the bottom left and then change the 400ohms to 500ohms on the picture on the right?
No. You should not convert 400 into 500.
You are supposed to find the resistance between a and b. 100 and 400 are not in series then. What is the procedure to get the Thevenin resistance?
Oh, they would be in parallel. So would I find my thevenin voltage by doing 80V(400ohms/500ohms)=64V?
Right!
R1 and R2 are in series. What is the quantity V1/(R1+R2)?
The current? And then you multiply by the resistance R2 to find the voltage there and that gives you the voltage Vout?
Right! It is derived from Ohm's law,V=IR.
Then why can I use that here in this circuit if they are in parallel?
For the original voltage source in your diagram, 100Ω and 400Ω are in series. For calculating Thevenin voltage, you make use of that original voltage source. To find the Thevenin resistance, you short the original voltage source and then proceed. 100Ω and 400Ω are in parallel when "viewed from port a-b".
Hence, 100Ω and 400Ω will be parallel for Thevenin voltage source but are in seeies fot the original voltage source.
Ok so if they are parallel for the thevenin voltage source, then why can I use that same equation for finding the thevenin voltage? if they are in parallel.
ANd9GcSvMaZwjm5cDFNoc9x_A2YDKfw06RtsS1ipPWgp669W0KVPEp_OGQ&hash=f5aefea7d75d010020a7658f31c53235.png
Rth=Vth/IN.
=Voc/Isc
This method is commonly used when there are dependent sources in the circuit.
oh, ok. that makes more sense now. So how would I find the norton equivalent? Would I use the do In= Vth/Rth? Would Rth be found by adding the 100ohm and 400ohm in parallel?
Yes. And it will be in parallel with the Norton current source.
Likes Marcin H
Ok. I got .8A. The original problems says to find the Norton equivalent at terminals a-b for the circuit shown. Do I just have to find the value or do I have to redraw the circuit with a current source and norton(equivalent) resistance?
I guess they are expecting you to redraw the circuit.
1. What is Norton's Theorem?
Norton's Theorem is a circuit analysis technique used to simplify a circuit with multiple resistors and current sources into an equivalent circuit with a single current source and a single resistor. This simplification is useful for calculating the current and voltage in a particular part of the circuit.
2. How do you calculate the Norton equivalent current?
To calculate the Norton equivalent current (IN), you need to find the short-circuit current (ISC) in the original circuit. This can be done by replacing all the resistors in the original circuit with their respective Norton equivalent resistors and then applying Ohm's law (ISC = VTH/RTH). The resulting IN will be the same as ISC.
3. What is the difference between Norton and Thevenin equivalent circuits?
The main difference between Norton and Thevenin equivalent circuits is that Norton uses a current source and Thevenin uses a voltage source. In Norton's Theorem, the current source is in parallel with the Norton equivalent resistor, while in Thevenin's Theorem, the voltage source is in series with the Thevenin equivalent resistor.
4. Can you use Norton's Theorem for AC circuits?
Yes, Norton's Theorem can be applied to both DC and AC circuits. However, the calculations for the Norton equivalent current and resistor may differ depending on the type of circuit. For AC circuits, impedance (Z) is used instead of resistance (R) in the calculations.
5. How do you use Norton's Theorem to solve a circuit problem?
To use Norton's Theorem to solve a circuit problem, you first need to identify the part of the circuit you want to analyze. Then, you can replace the circuit with its Norton equivalent circuit, calculate the Norton equivalent current and resistor, and use them to determine the voltage and current in the desired part of the circuit. Finally, you can convert the solution back to the original circuit if needed.
  • Electrical Engineering
