Homework Help: Notation - Perms & Combs?
  1. Mar 4, 2015 #1
    Merlin3189
    Edit = Solved. My error.
    1- ##\Big( \frac {n_1 +n_2}{n_1} \Big)## in Siegel,S "Nonparametric Statistics" P.153 re. Randomization test for 2 independant samples.
    eg. ##\Big( \frac {4 + 5}{4} \Big) = 126##
    Used in calculating number of "equally likely ways" data could have been assigned under H0
    The brackets seem to be in heavier type and larger than BODMAS brackets.
    So what does this notation mean? How do I evaluate it?
    I should say I am not a mathematician, though I do have access to a retired A-level teacher, who has not been able to enlighten me. I do have A-level maths (but Pure with Mechanics, rather than Stats) and have used Siegel as a recipe book for doing stats in behavioural science. I don't remember using this test before, but its description seems appropriate to my data. It's simply that I can't evaluate his formula, because I don't recognise the notation.
    2-Relevant nCr = ##\frac{n!}{r! (n-r)!}##
    eg. 5C4=##\frac{5!}{4!1!}##=5
    nPr = ##\frac{n!}{ (n-r)!}##
    eg. 5P4 = ##\frac{5!}{ (1!}## = 120
    Binomial Coefft = ##\frac{n!}{k! (n-k)!}##
    which looks remarkably like nCk
    n! = n(n-1)(n-2).....1 eg. 5!=5x4x3x2x1 = 120
    rn = r*r*r*r... n times eg. 54=5x5x5x5=625
    3-attempts
    Searched Google for Math notation re. brackets and braces.
    Found examples of its use for Combinations and for Binomial Coeffts.
    Evaluated
    9C4=##\frac{9!}{4!1!}##= 9x8x7x6x5 > 126 EDIT - Error!
    9C5=##\frac{9!}{5!1!}##= 9x8x7x6 > 126 EDIT - Error!
    Could not work out a different result for Bin(4+5,4 or 5) because it just seemed to be the same as the combinations.
    Factorised 126 = 2 x 3 x 3 x7 (maybe = 3! x (3-2)! x 7! / 6! ?)
    I suppose I could work out the number of ways I think the data (9 items in the example) could be assigned to 2 groups (of 4 and 5), but I suspect I'd arrive at
    nCr again.
    In the group of 5, there are 9 choices for 1st position, 8 for next, ..
    = 9x8x7x6 = 3024
    Once these are assigned, all the rest must be in the group of 5.
    There are 9 data, each can be in one of two groups, so
    2 choices for first, 2 choices for second, ......
    = 2x2x2....= 2^9= 512 ways of assigning 9 data to 2 groups, from AAAAAAAAA to BBBBBBBBB via for eg. AABBABABB
    But only 4 can be in one group and 5 in the other, so I should reduce this.
    I need to count only AAAABBBBB , BABABABAB, etc and discard AAAAABBBB, AAAAAAAAA, AAAAAAAAB etc.
    So I can discard
    1 like AAAAAAAAA and 1 like BBBBBBBBB
    9 like ABBBBBBBB and 9 like BAAAAAAAA
    36 like AABBBBBBB and 36 like BBAAAAAAA
    84 like AAABBBBBB and 84 like BBBAAAAAA
    and 126 like BBBBAAAAA
    Total 386, leaving 512-386= 126 as required
    So I'm happy that he got the correct result, but how did he calculate it from (5+4)/5 or from (5+4)/4 ?
    I ended up using 2^(5+4) - 2xC(9,0) -2xC(9,1) -2xC(9,2) -2x(9,3) -2xC(9,4) -C(9,5) which is cumbersome to say the least.
    Since he uses this wierd notation, it seems likely that it is a well known function.
    And since when I come to apply it, I have 65 data in groups of 17 and 48, my ab initio process will be tedious! If I understood his method (hidden in this bracket notation) perhaps it would help me see something I have not observed.
    I understand that if, I want to be a mathematician, I must work out everything from first axioms and build my own framework, but I'm just trying to evaluate my data. Much as I'd love to be a mathematician, I don't think I have the time.
    2. Relevant equations
    3. The attempt at a solution
  3. Mar 4, 2015 #2
    PeroK
    You've simply got a non-standard notation for binomial coefficients.
    I learned these as ##^nC_r## but ##\binom{n}{r}## seems to be more common.
    ##\binom{5+4}{4} = \binom{9}{4} = 126##
    Rathers gives it away.
    There's more here:
    http://en.wikipedia.org/wiki/Binomial_coefficient
  4. Mar 4, 2015 #3
    Merlin3189
    Thanks for the response. I'm sorry, I just miscalculated when I evaluated it, or I would have realised that's what it meant.
    I wish I could delete it!
Have something to add?
Draft saved Draft deleted
Loading...
