Notation Q: What Does F(y/x) Mean?
  • Thread starter theperthvan
  • Tags
    Notation
In summary, F(\frac{y}{x}) in the context of a differential equation means that the right-hand side is a function of y/x. This function can take different forms, such as a constant or a more complex function, but it must be explicitly written as a function of y/x for the equation to hold.
theperthvan
184
Hi, Just a question on notation. What does [tex]F(\frac{y}{x}) [/tex] mean?
It is in the context of..."the differential equation [tex] y' = F(\frac{y}{x}) [/tex] can be solved dadadadada..."
Cheers,
Mathematics news on Phys.org
It just means the right-hand side is a function of y/x. This could be a constant function, like F(y/x)=0, which would be trivial and silly, or something like F(y/x) = (y/x)^2 + (1/2)(y/x). Basically, if you can rearrange the right-hand side of the equation to explicitly be a function of y/x, whatever follows in your text will hold.
For example, if you have the equation y' = x + 2, there is no way to write the right-hand side as a function of y/x. Writing it as y' = x*(y/x)*(y/x)^(-1) + 2 still includes x independently, so whatever follows that sentence in your book will not work for this type of equation.
Hi there,
In this context, F(y/x) most likely refers to a function that takes the ratio of y and x as its input. So, in the differential equation y' = F(y/x), the function F is being applied to the ratio of y and x. This notation is commonly used in differential equations, where F represents a general function that depends on the variable y/x. I hope this clarifies the notation for you. Let me know if you have any further questions. Happy learning!
1. What is the meaning of F(y/x)?
F(y/x) is a mathematical notation that represents a function of the variable y divided by the variable x. It is read as "F of y over x."
2. How is F(y/x) different from F(x/y)?
F(y/x) and F(x/y) are different functions, as the order of the variables changes the input and output of the function. For example, F(y/x) would have a different value than F(x/y) when substituting different values for x and y.
3. Can F(y/x) be simplified?
It depends on the specific function F. In some cases, it may be possible to simplify F(y/x) by factoring out common terms or using other mathematical techniques. However, not all functions can be simplified in this way.
4. How is F(y/x) used in real-world applications?
F(y/x) can be used in various fields such as physics, engineering, and economics to represent relationships between two variables. For example, in physics, F(y/x) could represent the force applied to an object divided by its displacement.
5. Are there any other notations similar to F(y/x)?
Yes, there are many similar notations used in mathematics such as g(x) or h(x) that represent functions of a single variable. F(y/x) specifically represents a function of two variables, y and x, divided by each other.
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
