Notation Question
  • Thread starter bomba923
Let's say I have a set {A}. How do I denote the largest member of that set?
For example, let's say I have a solution set of discrete values. How do I denote the largest solution?
Basically, with any set, how do I denote the largest member of that set? What symbol/s do I use !?
Answers and Replies
arildno
Dearly Missed
9,970
132
What's wrong with something like [tex]max(A)[/tex]??
That is the formal/accepted way of expressing it (the largest member of a set), right?
honestrosewater
Do maximums differ from least upper bounds (supremums)? The definitions I found didn't clear this up. Edit: Eh, because I was going to say supremum.
AFAIK, the maximum of a set must necessarily be a member of the set as well. So for example, {1 - 1/n; n a natural} has a supremum, but no maximum.
matt grime
9,395
Muzza is absolutely correct.
given a set (presumably of real numbers) there is no reason for that set to even have a greatest element, even if it is bounded above (ie all elements are less than some constant K). The sup is the smallest such K that bounds them above, and this is the max if and only if K is an element of the set.
Note, that this only applies to infinite sets. Any finite set of points must have a maxmimum.
Related Threads on Notation Question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
