Generate Permutations from Combinations Algorithm
In summary, a permutation is a rearrangement of elements in a specific order, while a combination is a selection without regard to order. The main difference between the two is the importance of order. A permutation from combination algorithm is a method of generating all possible permutations by using combinations as a starting point. This is achieved by rearranging the elements in every possible order.
mtanti
172
Does an algorithm exist for generating a particular permutation of a combination? You just input the combination and the position of the permutation and it outputs the permutation.
Computer science news on Phys.org
permutation #... yes i have one...but it prolly exists elsewhere too ..very simple algo .
ok but can you explain how it works? :/
What is a permutation?
A permutation is a rearrangement of a set of elements in a specific order. It is a way of arranging objects or values in a defined sequence, where the order of the elements matters.
What is a combination?
A combination is a selection of elements from a set without regard to order. It is a way of choosing objects or values without considering the arrangement or sequence they are in.
What is the difference between permutation and combination?
The main difference between permutation and combination is that in permutation, the order of the elements matters, whereas in combination, the order does not matter. Permutation is a rearrangement, while combination is a selection.
What is a permutation from combination algorithm?
A permutation from combination algorithm is a method of generating all possible permutations of a set of elements using combinations as a starting point. It involves taking each combination and rearranging its elements in every possible order to create all the potential permutations.
How does a permutation from combination algorithm work?
The algorithm works by first generating all possible combinations of the given set of elements. Then, for each combination, it creates all the possible permutations by rearranging the elements in every possible order. This process is repeated until all permutations have been generated.
  • General Math
  • Science and Math Textbooks
  • General Math
  • Math Proof Training and Practice
