Exploring Nth Roots of Numbers and the Role of Complex Numbers
  • Thread starter tut_einstein
  • Tags
    Roots
In summary, the use of complex numbers is necessary in finding all n roots of a number because the complex numbers are algebraically closed, meaning every polynomial of degree n has n complex roots. This is due to the fact that i, when adjoined to the real numbers, creates an algebraically closed field. The existence of nth roots of a number is a result of the Fundamental Theorem of Algebra, which states that every polynomial of degree n over the complex numbers has exactly n roots. This theorem is not immediately obvious from the definition of i and is a nontrivial result.
tut_einstein
31
I'm slightly confused about why complex numbers are required to find all n roots of a number. Is it specifically because of the fact that you can represent complex numbers as a rotation of the plane? I understand why a number should have n roots, I'm just not sure which part of the definition of complex numbers allows this.
Thanks!
Finding nth roots of a number c is the same as finding the roots of the polynomial [itex] x^n - c[/itex]. The real numbers are not algebraically closed, meaning there are nonconstant polynomials that have no roots, such as [itex] x^2 + 1 [/itex]. The complex numbers are algebraically closed, so every polynomial of degree n has n complex roots. (They are in fact the algebraic closure of the reals.) It's kind of miraculous, actually, that adjoining a single element, namely [itex] i [/itex] gives us an algebraically closed field.
One special class of roots are roots of unity, i.e. numbers such that [itex] \zeta^n = 1[/itex] for some positive integer n. For instance, suppose we're trying to find the cube roots of 2, considering the polynomial [itex] x^3 - 2[/itex]. This has one real solution, namely the unique real number we have named [itex] \sqrt[3]{2}[/itex]. However, there are 2 more complex solutions, namely [itex] \sqrt[3]{2} \zeta[/itex] and [itex] \sqrt[3]{2} \zeta^2[/itex], where [itex] \zeta[/itex] is a primitive cube root of 1, like [itex] e^{2 \pi i/3}[/itex].
"It's kind of miraculous, actually, that adjoining a single element, namely i gives us an algebraically closed field."
La goutte qui fait déborder le vase.
I had to look that one up. Literally "the drop of water that makes the vase overflow." Or as we say in the U.S., the straw that broke the camel's back.
it simply means that not all straws or drops have been created equal.
I'm just making sure I got this. So, the reason a number can have n nth roots when using complex numbers is because of the way that i is defined? So, if one defined some other different k, would it be possible to find say n+1 nth roots? I guess my question is: does the fact that the polynomial x^n - c =0 has n roots, something that holds true independent of the way complex numbers are defined?
Thanks!
Over any field (or integral domain), a polynomial of degree n can have at most n roots. So if we're dealing with the polynomial [itex]x^n -c[/itex] (which is of degree n) over the real or complex numbers (or the rationals or integers), you can never have n+1 nth roots. But maybe you could if you were instead working over a ring that had zero divisors.
The fact that every polynomial of degree n over the complex numbers has exactly n roots is called the http://en.wikipedia.org/wiki/Fundamental_theorem_of_algebra" . Just to be clear, this is a nontrivial result and is not immediately obvious from the way i is defined. I don't think I saw this theorem until a couple months into my complex analysis class.
Yes, I guess that was my basic question. The fundamental theorem of algebra is not a result of the way i is defined, right? So i had to be defined the way it is so that the fundamental theorem of algebra will hold...
1. What are Nth roots of a number?
The Nth root of a number is a mathematical operation that calculates a number (called the root) that, when multiplied by itself N times, gives the original number. For example, the 2nd root of 9 is 3, since 3 multiplied by itself 2 times equals 9.
2. How do you find the Nth root of a number?
To find the Nth root of a number, you can use the formula: Nth root = number^(1/N). This means taking the number and raising it to the power of 1/N, where N is the desired root. For example, to find the 3rd root of 8, you would calculate 8^(1/3), which equals 2.
3. Can the Nth root of a negative number be a real number?
Yes, the Nth root of a negative number can be a real number. However, the N must be an odd number. For example, the 3rd root of -8 is -2, since -2 multiplied by itself 3 times equals -8.
4. What is the difference between Nth root and square root?
The main difference between Nth root and square root is the value of N. Square root is a specific case of Nth root, where N is equal to 2. This means that the square root of a number is the same as the 2nd root of that number.
5. Can the Nth root of a number be a complex number?
Yes, the Nth root of a number can be a complex number. This is possible when the number under the root is negative, and N is an even number. In this case, the result will be a complex number with a real part and an imaginary part.
  • Linear and Abstract Algebra
  • General Math
  • Classical Physics
