Homework Help: Number problem
  1. Mar 1, 2016 #1
    Given are two integers a and b: a has 2 digits and b has 4 digits. All digits are smaller than 9. a and b are such that [itex] a^2 = b [/itex].
    If all digits are raised by one this is still valid. What are a and b?
    2. Relevant equations
    N/a
    3. The attempt at a solution
    Suppose [itex] a = a_0 \cdot 10^0 + a_1 \cdot 10^1 [/itex]
    and [itex] b = b_0 \cdot 10^0 + b_1 \cdot 10^1 + b_2 \cdot 10^2 + b_3 \cdot 10^3 [/itex]
    then it gets messy if I use [itex] a^2 = b [/itex] and if I increase all digits by one.
    I think should get two equations with 2 unknowns.
  3. Mar 1, 2016 #2
    Why don't you try to find the relationship between the numbers whose digits have been increased by one and the originals ( for both 2 and 4 digits?)
    Take specific examples to help if you want to.
  4. Mar 1, 2016 #3
    PeroK
    Start by looking at squares modulo 10 and think about conditions on ##a_0## and ##b_0##
  5. Mar 1, 2016 #4
    haruspex
    I see no benefit in having separate variables for the digits.
    The question wording is a little strange... in what sense 'valid'? I guess they mean that all the conditions for a and b are still true after elevating each digit. Because all digits are less than 9, you can very easily write an algebraic equation representing that the new a and b also satisfy the quadratic relationship. After that it's straightforward.
  6. Mar 1, 2016 #5
    The nice thing with this problem is that you can narrow down your list of possible answers if you can never solve using relationships (although you should try to use them!). Because of the requirements, you know that a has to be between 32 and 87, with many of those numbers in there also not being possibilities. I wondered how long it would take to solve using guess and check (again, not the ideal method) and I guessed a on my first try! :)
    Just to point out that there are always other approaches if you ever get really stuck on an exam or something
  7. Mar 1, 2016 #6
    So solve:
    [itex] a^2=b[/itex] and [itex]
    (a+11)^2=(b+1111)[/itex]
    => a =45 and b = 2025.
  8. Mar 1, 2016 #7
    haruspex
    That's what I get.
  9. Mar 6, 2016 #8
    a2=b
    then:
    (a+10+1)2=b+1111
    this is the add one to each digit
    a2+22a+121=b+1111
    then rearrange onto one side
    a2+22a-b-990=0
    and as seen from the start
    b=a2
    so
    a2+22a-a2-990=0
    so
    22a-990=0
    so
    22a=990
    and
    a=990/22
    =45
    then substitute this back into the original equation
    452=b
    b=2025
    then to check:
    562=3136
    hope that helps
  10. Mar 6, 2016 #9
    haruspex
    This appears to be just an elaboration of post #6.
  11. Mar 7, 2016 #10
    yes sometimes it is easier explained
  12. Mar 7, 2016 #11
    haruspex
    I don't think dirk_mec needs his own working explained to him.
  13. Mar 12, 2016 #12
    What about others that are viewing the post?
Have something to add?
Draft saved Draft deleted
Loading...
