Numbers for which it coverges
  • Thread starter zeion
zeion
467
Find the positive numbers r for which [tex]\sum \frac{r^k}{k^r}[/tex] converges.
What method do I use for this?
[tex]\frac {a_{k+1}}{a_k} = \frac {r^{k+1}}{(k+1)^r} \cdot \frac{k^r}{r^k}
= r \cdot (\frac{1}{k})^{\frac{r}{k}} [/tex]
Answers and Replies
8,181
The second and third expressions aren't equal...
zeion
467
Ok so I have [tex] \frac {a_{k+1}}{a_k} = \frac {r^{k+1}}{(k+1)^r} \cdot \frac{k^r}{r^k}
= r \cdot \frac{k^r}{(k+1)^r } = r \cdot (\frac{k}{(k+1)})^r[/tex] ?
zeion
467
then [tex]r \cdot (1 - \frac{1}{k+1})^r \to r \cdot 1^r [/tex] ?
zeion
467
then r needs to be < 1?
zeion
467
I thought if the ratio is < 1 then it converges?
8,181
The ratio test is usually given in terms of absolute values. IOW,
[tex]\lim_n \frac{|a_{n + 1}|}{|a_n|}[/tex]
For this problem it's given that r is a positive number, so since the ratio of those terms is less than 1, the series converges.
zeion
467
So how do I know the ratio is less than 1?
8,181
I thought you already knew that. What I thought you did was to evaluate this limit:
[tex] \lim_{k \to \infty} \frac {a_{k+1}}{a_k} = \lim_{k \to \infty} \frac {r^{k+1}}{(k+1)^r} \cdot \frac{k^r}{r^k}= \lim_{k \to \infty} r \cdot \frac{k^r}{(k+1)^r } = \lim_{k \to \infty} r \cdot (\frac{k}{(k+1)})^r[/tex]
What do you get for this limit? And what does that value imply for the test you are using?
zeion
467
I get [tex]r \cdot 1^r = r[/tex]?
And r is positive
8,181
converges.
From your work, what are the values of r that cause this series to converge?
zeion
467
I need the ratio to approach something < 1?
So since r is positive I need it to be 0 < r < 1?
8,181
C'mon, show some confidence. Tell me, don't ask me.
8,181
C'mon, show a little confidence in your ability. Tell me, don't ask me.
Suggested for: Numbers for which it coverges
