Homework Help: Numerical variational problem
  1. Jul 15, 2014 #1
    Here I am, trying to get the trajectory $(x(t),y(t))$ that will minimize the following Lagrangian (i.e. the integrand of the functional) between $(-1,-1)$ and $(-1,y_{eff})$ where $x_{eff}$ is defined as the point where $V(x_{eff},-1)=V(-1,-1),x<0$.
    So here's the integrand of the functional:
    $L=\frac{1}{2}((\partial_tx)^2+(\partial_ty)^2)-V(x(t),y(t))$
    with $V(x(t),y(t))$ defined as follows:
    $(x(t)^2-1)^2(x(t)^2-\delta_1)+\frac{(y(t)^2-1)^2-\frac{\delta_2}{4}(y(t)-2)(y(t)+1)^2}{x(t)^2+\gamma}$
    and
    $x(0.0001)=-1=y(0.0001)$
    $x(10)=x_{eff},y(10)=-1$
    2. Relevant equations
    The polar-coordinate Euler-Lagrange equation
    3. The attempt at a solution
    Code (Text):
    Needs["VariationalMethods`"];
    gamma = 0.1;
    delta1 = 0.1;
    delta2 = 0.1;
    tmin = 0.0001;
    tmax = 10;
    V[x[t_], y[
        t_]] := (x[t]^2 - 1)^2 (x[t]^2 -
          delta1) + ((y[t]^2 - 1)^2 - (delta2 (y[t] - 2) (y[t] + 1)^2)/
           4)/(x[t]^2 + gamma);
    U[x_, y_] := (x^2 - 1)^2 (x^2 - delta1) + ((y^2 - 1)^2 -
          delta2 (y - 2) (y + 1)^2/4)/(x^2 + gamma);
    ftn = 2*Pi*
      t (1/2 (D[x[t], t]^2 + D[y[t], t]^2) +
        V[x[t], y[t]]); (* Le Lagrangien *)
    Veff[x_] := U[x, -1];
    x0 = x /. FindRoot[Veff[x] == U[-1, -1], {x, -0.2}]
    sln = EulerEquations[ftn, {x[t], y[t]}, t]
    solution =
      NDSolve[{sln, x[tmin] == -1, y[tmin] == -1, x[tmax] == x0,
        y[tmax] == -1}, {x[t], y[t]}, {t, tmin, tmax}];
    psi[t_] = x[t] /. solution[[1, 1]];
    phi[t_] = y[t] /. solution[[1, 2]];
    NIntegrate[
     t (1/2 (D[psi[t], t]^2 +
           D[phi[t], t]^2) + ((psi[t]^2 - 1)^2 (psi[t]^2 -
             delta1) + ((phi[t]^2 - 1)^2 -
             delta2 (phi[t] - 2) (phi[t] + 1)^2/4)/(psi[t]^2 +
             gamma))), {t, tmin, tmax}]
    Plot[{psi[t], phi[t]}, {t, tmin, tmax}, PlotRange -> All]
    ParametricPlot[{psi[t], phi[t]}, {t, tmin, tmax}, PlotRange -> All]
    But, when I run that piece of Mathematica code, I run into an error message:
    Code (Text):
    NDSolve::ndsz: At t == 0.004410099463404809`, step size is effectively zero; singularity or stiff system suspected.
    Because of the stiffness of the system the numerical solution has a strange behavior...
  3. Jul 15, 2014 #2
    Ray Vickson
    For inline equations, use either [i tex] xxxx [/i tex] (no spaces between i and t), or else # # xxx # # (no spaces betweent the two #s). For displayed equations, use [t ex] equations [/t ex] (no spaces between t and e). For example, ##V(x_{eff},-1)=V(-1,-1),x<0## and
    [tex] L=\frac{1}{2}((\partial_tx)^2+(\partial_ty)^2)-V(x(t),y(t)).[/tex]
Have something to add?
Draft saved Draft deleted
Loading...
