Can O2 and H2O eliminate algae in fish ponds?
  • Thread starter Robin07
In summary: If you could supplement your hydro usage or take it from a battery system that's re-energized with solar energy... this would be the next best thing you could do with what you have to work with.. Thanks Dave, Chemisttree.
Robin07
139
The reason I'm asking this elementary question is that I have, now for three years running induced oxygen into my 32"deep x 16' OD fish pond. What I've found is that when I introduce the atomized oxygen into the pond, all the algae disappears within three days if I have the oxygen pump running for 4 to 6 hrs.
What peaked my curiosity is that there are hundreds of products on the market that promote algae reduction at best and really none of them really works as well as what I just tripped over...Yes?
Thanks guys
something to chew
Robin
Chemistry news on Phys.org
Aeration/circulation has been known for some time to reduce algae growth. Aeration sparges out excess CO2 from the water and limits the growth of algae. Also, some algae grows better in stagnant water near the margin of the pond. Circulation helps keep it in check.
Thanks, It's interesting that you'd say that the edge of the pond is more likley to have stagnant water. I so designed the pond to be a sandwich using two flattended bowls. The lower bowl is the linner and the second interior layer allows water to penatrate down through its' mesh. The aeration is released in between this sandwich at its' central lowest elevation. The bubbles don't penatrate the mesh surface as it travels to the suface but does travel to the upper perimeter/margin of the pond, in effect circulating the water in the pond through aeration.
I have also found that the surrounding area of the pond is allot more lush, moist. What I'm wondering is... The air is also very much cooler. And in the interest of 'globel warming'. If more people adopted an O2 + H2O induction system could we, as a collective body, be cooling the Earth?
Thanks again
Robin
1] It feels cooler because its moisture content is higher, meaning it makes for better heat transfer and thus reomoval of heat from your skin.
2] You're using electricity to power the pump. It's generating heat and using power from a power plant. So, even if it were having a local cooling effect, the net energy usage and thus heat generation goes up.
I'm sorry about not knowing how to post a quote as you did so I just copied and pasted... and as well as getting off of the track in-regards to the Chemistry end of things.
Quote:
2] You're using electricity to power the pump. It's generating heat and using power from a power plant. So, even if it were having a local cooling effect, the net energy usage and thus heat generation goes up. End Quote.
So, if I could supplement my hydro usage or take it from a battery system that's re-energized with solar energy... this would be the next best thing I could do with what I have to work with.. Thanks Dave, Chemisttree.
I think I might need to converse with some solar energy engineers to pursue this any further and some thermal extraction engineers so that I may be able to extract heat from my ice pack/pond, to off set some winter heating costs. Ambisious... I know but what do you get when one doesn't"t try?
Thanks Again
Robin
What is the chemical equation for O2 + H2O?
The chemical equation for O2 + H2O is 2H2O + O2.
What is the significance of O2 + H2O in the environment?
O2 + H2O is a key reaction in the environment as it produces oxygen, which is essential for many living organisms, and water, which is necessary for sustaining life.
What type of reaction is O2 + H2O?
O2 + H2O is a combustion reaction, as oxygen is reacting with a fuel (hydrogen) to produce heat and energy.
Can O2 + H2O be reversed?
Yes, O2 + H2O can be reversed by the process of photosynthesis. In this process, plants use energy from sunlight to convert carbon dioxide and water into oxygen and glucose.
What is the overall result of O2 + H2O?
The overall result of O2 + H2O is the production of energy, oxygen, and water. This reaction is essential for sustaining life on Earth.
