Can an object lose weight just by moving higher above the Earth?
  • Thread starter physics(L)10
  • Tags
    Weight
In summary, to lose 30% of its weight, an object must be at a radius of r=0.30GMearth/4pi^2, larger than the Earth's radius, where G is the gravitational constant and Mearth is the mass of the Earth. This can be calculated using the equation ma=Gm(Mearth)/r^2, where a is the acceleration due to gravity and m is the object's mass. Time does not play a role in this calculation.
physics(L)10
101
How far above the Earth must an object be in order to lose 30% of its weight?
ma=Gm(Mearth)/r^2
a=v^2/r
v=2pir/T
I think the 30% lost weight would be the same as the Earth's weight losing 30%. Therefore, I can put Mearth=(0.30)(6x10^24)
We have to solve for r to find the radius and then subtract it from the radius of the Earth to find where this object is.
So rearranging the equation we get:
4pi^2r^3/T^2=0.30GMearth/r^2, where T=1 day and needs to be converted to seconds.
Finally, we rearrange to solve for r and get:
r=0.30GMearth/4pi^2
ma=Gm(Mearth)/r^2
a=v^2/r
v=2pir/T
r=0.30GMearth/4pi^2
Time has no place in this calculation.
Don't try to think of it in terms of reducing the mass of the Earth. That's not good intuition.
Use the main equation you list, and calculate the radius that's larger than the Earth's radius that results in the listed decrease in *force*.
1. How does "Object to lose weight" work?
"Object to lose weight" works by using a combination of advanced technology and scientific principles to help individuals achieve their weight loss goals. This object may use methods such as tracking calorie intake, monitoring physical activity, and providing personalized meal plans to help individuals lose weight effectively.
2. Is "Object to lose weight" safe to use?
Yes, "Object to lose weight" is designed and tested by scientists and health professionals to ensure its safety. However, it is always important to consult with a doctor before starting any weight loss program.
3. Can "Object to lose weight" guarantee weight loss?
Every individual's body is unique, and weight loss results may vary. "Object to lose weight" is designed to support and assist individuals in their weight loss journey, but ultimately, the success depends on consistent effort and dedication from the user.
4. How long does it take to see results with "Object to lose weight"?
The time it takes to see results may vary depending on individual factors such as starting weight, metabolism, and adherence to the program. However, most individuals may see noticeable changes within a few weeks of consistent use.
5. Can "Object to lose weight" be used by anyone?
While "Object to lose weight" is designed to be safe for most individuals, it is important to consult with a doctor before use, especially for those with pre-existing medical conditions or taking any medication. Pregnant or breastfeeding women should also consult with their doctor before using this product.
