Obtain Oxygen: Break Apart CO2 or H2SO4?
  • Thread starter Anon Imous
  • Tags
    Oxygen
In summary, it is possible to obtain oxygen by breaking apart Carbon Dioxide or Sulphuric Acid through various methods such as electrolysis of water or using a magnesium flame. However, these methods may also produce other byproducts and should be done with caution.
Anon Imous
Is it possible, and if so how, to obtain oxygen by breaking apart Carbon Dioxide or Sulphuric Acid?
Chemistry news on Phys.org
Ask any plant.
Anon Imous said:
or Sulphuric Acid?
You can obtain oxygen and hydrogen by electrolysis of water,in the ratio 1:2,respectively.
. You will need to add some Sulphuric acid to increase conductivity.
A good way to get oxygen is mixing bleach and hydrogen peroxide. Fun little home experiment.
But, don't be stupid enough to breathe this, if any peroxide vapor is in the mix, it would be very dangerous for you.
A magnesium flame is able to continue burning in CO2 because the reaction is sufficiently energetic to be able to break apart CO2 and consume the oxygen while liberating carbon.
What's the use of this if we don't get Oxygen as a product here?
1. How is oxygen obtained from CO2 or H2SO4?
Oxygen can be obtained from CO2 or H2SO4 through a process called electrolysis. In this process, an electric current is passed through a solution of CO2 or H2SO4, causing the molecules to break apart and release oxygen.
2. Why is it important to obtain oxygen from CO2 or H2SO4?
Oxygen is an essential element for life on Earth. It is used by plants during photosynthesis to produce energy, and it is also needed for cellular respiration in animals and humans. By breaking apart CO2 or H2SO4, we can obtain the oxygen necessary for these important processes.
3. Is obtaining oxygen from CO2 or H2SO4 a sustainable process?
Yes, obtaining oxygen from CO2 or H2SO4 can be a sustainable process if renewable energy sources, such as solar or wind power, are used to power the electrolysis process. This would reduce the reliance on non-renewable resources and decrease the carbon footprint of the process.
4. What are the potential applications of obtaining oxygen from CO2 or H2SO4?
The obtained oxygen can be used for a variety of applications, including industrial processes, medical treatments, and even in space exploration. It can also be used to produce clean energy through hydrogen fuel cells.
5. Are there any challenges or limitations to obtaining oxygen from CO2 or H2SO4?
One of the main challenges is the high energy requirement for the electrolysis process. This can be costly and can also contribute to carbon emissions if non-renewable energy sources are used. Additionally, the purity of the obtained oxygen may be affected by impurities in the CO2 or H2SO4 solution.
  • Chemistry
  • Chemistry
