Odd Gauss's Law question
  1. Jan 27, 2010 #1
    Calculate E inside and outside an infinite cylinder of uniform volume charge density using the differential form of Gauss's law.
    2. Relevant equations
    [tex]\nabla[/tex] E = [tex]\frac{p}{e0}[/tex]
    p = charge density
    Divergence in cylindrical polars:
    3. The attempt at a solution
    I'm aware this is much easier using the integral form. I have no problem with calculating E field of various symmetrical shapes using the integral form. However I specifically have to use the differential form. I've never seen an example of this and have looked for quite a while, and I'm not really sure what I'm doing at all.
    All I can think is that by symmetry, differential of E in terms of theta and z are zero, but this still leaves an awkward derivative of E in terms of r, and I'm not sure what to do at that point.
  3. Jan 27, 2010 #2
    You have to use the awkward derivative, sorry. I am going to change symbols and use r for the radial coordinate and ρ for the volume charge density which is constant in this case. You get
    [tex]\frac{d(E_r r)}{dr}=\frac{\rho \; r}{\epsilon_0}[/tex]
    Can you solve this differential equation?
  4. Jan 27, 2010 #3
    That's pretty much what I did, but I didn't think to multiply through by r. After that the integration is quite straight forward, and by varying the limits accordingly I get the same result as by the integral form for E field both inside and outside the cylinder.
    Thanks a lot!
