Odd integration problem
  • Thread starter MuIotaTau
MuIotaTau
82
In the process of solving a physics problem, I've run across an integration that I'm not sure I've ever had to perform before. It's of the form $$\int \frac{1}{a - (\frac{dy}{dx})(x)} dx$$ where ##a## is a constant.
Table integral?
I honestly have no clue where to even begin with this. I do not have a functional form for ##y##, it's simply a quantity that changes with respect to ##x##. Any hints on where to begin?
Answers and Replies
Ray Vickson
Dearly Missed
10,706
1,722
Table integral?
Your notation is confusing: is the denominator supposed to be ## 1 - a x y'(x)## or ##1-a y'(x)##, where ##y'(x) = dy(x)/dx.## That is, is the (x) an argument of f', or does it multuply f'(x)?
As far as I can see you can write more-or-less ANY integrand h(x) in that form: just put
[tex] h(x) = \frac{1}{a-y'(x)} \Longrightarrow y'(x) = \frac{h(x)-1}{a h(x)} [/tex] if your integrand is 1/(1-ay'), or put
[tex] h(x) = \frac{1}{a - x y'(x)} \Longrightarrow y'(x) = \frac{1-h(x)}{a x h(x)}[/tex]
if your integrand is 1/(1-a*x*y').
So, to summarize: your integrand can be anything at all, so there is no way to do the integral.
MuIotaTau
82
I'm sorry, ##x## is being multiplied in the denominator. Well, um, that's certainly disappointing. I guess it's back to the drawing board. Thank you for your help!
Dick
26,263
619
If it's a physics problem you probably know something about the relation between y' and x. What kind of problem is it?
MuIotaTau
82
Momentum transport. In this case, ##x## is time, and ##y'(x)## is the change in mass with respect to time. So really the integral is $$\int_0^t \bigg(\frac{1}{M + m - (t')(\frac{dm}{dt'})}\bigg) dt'$$ where ##t'## is a dummy variable. ##M## and ##m## are the masses of a truck and of an original mass of sand, respectively, so they're constants, and ##(t)(\frac{dm}{dt})## is the amount of sand that falls out the truck after a time ##t##.
Dick
26,263
619
Since you are multiplying t' times dm/dt', I think it's pretty likely you are assuming the rate of mass change dm/dt' is constant. Are you?
MuIotaTau
82
Oh no, you're right, I certainly am! So I should be able to manipulate that into something of the form $$\int \frac{1}{1 + x} dx$$ right? Which is just ##ln(1 + x)##?
Dick
26,263
619
Sure, so the integral isn't a real problem. Now I'd worry that the integral is computing something like the average value of 1/mass over a portion of the trip, which doesn't sound very useful for momentum problems, but then I don't know exactly what you are doing.
MuIotaTau
82
I'm actually calculating the impulse and dividing by the mass to get velocity, but the force in this particular case happens to be time independent, so I just pulled it out of the integral.
Dick
26,263
619
Ok, carry on.
Suggested for: Odd integration problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
