Homework Help: Odd shaped beam maximum load
  1. Feb 13, 2013 #1
    This isn't homework, but I thought I would post it here as maybe more people would see it, and as I am not an engineer, it requires someone with more experience. The section is effectively an I beam with a hollow u shaped fitting along the top (see my rough sketch). I just need to know how to work out the maximum load at the end of the structure, as if it was cantilevered. I have Z, and dimensions of the materials.
    2. Relevant equations
    ___
    3. The attempt at a solution
    I probably have to calculate the moment of inertia, would it be somewhere towards the top of the "I" beam?
  3. Feb 13, 2013 #2
    SteamKing
    Staff Emeritus
    As long as the U-fitting is small and I think it is oriented across the top of the beam, you would ignore it in trying to determine the maximum load on the beam.
    If the U-fitting is intended to apply the load to the beam, that is another factor in determining how much load can be applied.
  4. Feb 13, 2013 #3
    Sorry about the diagram its meant to be as though you were looking at the I. The u fitting runs the length of the beam, and it as at least as wide as the beam. I wouldn't think it was of negligible size. It isn't intended to apply load to the top of the I beam.
Loading...
