dwepplo
- 1
Hi,
I’m trying to write a probing cycle on a CNC for calibrating from a standard.
I have a circle with a known diameter but it is not located on the center of rotation – the center of rotation is X/Y intercept.
The center of rotation will always lie within the circle.
I’m trying to write a function that describes the radius in terms of angle of rotation (A) – B is the center of known circle. I can only measure by rotating and I won’t know the distance from the axis – only the change in radius versus the angle of rotation.
This is what I’m planning:
I have to first find the coordinates of the center of the circle by rotating and measuring then use this data in the function for describing the radius.
Is this the best approach?
What is the approach for finding the center of the circle?
To describe the radius would I use polar coordinates, if so what does a shifted polar eqn look like?
It’s been a while since I’ve thought about some of these things and I’m hoping someone can point me in the right direction.
Thank you,
Dan
Thank you,
Dan
