Ohm's and Kirchhoff's simple problem
  • Thread starter savoylen
In summary, the conversation is about solving a circuit problem involving Ohm's and Kirchhoff's laws. The problem requires finding the values for current and voltage in different parts of the circuit. The conversation includes tips and approaches on how to solve the problem, as well as reminders on using Kirchhoff's laws correctly. The conversation also references a thread on the Physics Forum that provides a step-by-step solution to a similar problem. One of the main points emphasized is the need for setting up the equations correctly in order to solve the problem.
savoylen
Ohm's and Kirchhoff's "simple problem"
For the figure below solve for:
I(1) = ? mA V(1) = ? V
I(2) = ? mA V(2) = ? V
I(3) = ? mA V(3) = ? V
I don't seem to be able to apply the correct combination or Ohm's and Kirchhoff's laws to get the correct values? Tips on an approach here?
- Sav
Welcome to the Physics Forum?
Are you told you need to use K'..s laws here? In other words this circuit can be simplified witout resort to their use. Hint: Find an equivalent resistance for the 20 and 10 ohm resistors.
In the future, it is best to show some effort on solving the problem using standard format, before expecting help.
I'm taking electricity and magnetism and I got questions like these, use Kirchoff's laws even if not necessary for practice sake. First write the junction equation or sum of all the currents should equal? Then for each loop(as you can see there are two loops, or two small rectangles on the big one) write a equation, remember if you are going in the direction of the current on any resister it would have a voltage drop or negative and against would be the opposite or positive. Also, on the left loop there is an electromotive force or simply a voltage provider for the whole circuit. You should be aware what direction you are traveling on the loop and the direction of the current, very important!
Using Kirchoffs loop rule for the parallel loop proves that the voltage drop across both is resistors is the same. Only the current varies between parallel resistors
Yes, you are correct, but if you use Kirchoff's law, the math will do all the work for you, not much thinking required as long as you know his rules.
Yes, new here and just starting in circuits.
Sorry about the nettiquete slip... still learning about this forum. I think I saw a form somewhere when I first started looking through the site, but don't see it now. I'll brush up on that before my next post! :eek:
I should have said that I'm looking for a way to get started... thanks for the tips!
TO the poster regarding Ohm's and K's laws, yes that is all he have to work with for this problem. I'm sure them must be a good reason ;)
If I look at them all at the same time going counterclockwise starting at the bottom I get...
-I(R3) - I(R2) -I(R1) + 6V = 0 (Kirchhoff)
-I(20) - I(10) -I(10) + 6V = 0 (sub.)
I = 0.15 A (solved)
So I get 0.15 amps for the current for the circuit.
I(R1) = 1.5 V
I(R2) = 3.0 V
I(R3) = 1.5 V
Which looks ok for the 6 V emf.
But... shouldn't my current be the same for the two resistors in parrallel (R2 and R3)?
I'm sure I'm just not looking at the circuit in the right 'chuncks' ;(
Using just Ohm's law, and Kirchhoffs current and voltage laws are all I have to work with at this point.
VinnyCee said:
https://www.physicsforums.com/showthread.php?t=163329". The methods are the same for your circuit. Also, post pictures using the picture icon so they are easier to read.
Welcome to PF!
Thanks! Nice to be here... the thread looks like just what I needed, but unfortunately I can't see any of the graphs (just a big X where they should be)... any way I can get you to repost those? o:)
I = 0.15 A (solved)
I(R1) = 1.5 V
I(R2) = 3.0 V
I(R3) = 1.5 V
But... shouldn't my current be the same for the two resistors in parallel (R2 and R3)?
I'm sure I'm just not looking at the circuit in the right 'chucks' ;(
Using just Ohm's law, and Kirchhoff's current and voltage laws are all I have to work with at this point.
Your equations are not set up right:
I. write a junction equation: ie. In the form of I(net)=I1-I2-I3=0 or you can write I1=I2+I3 which are pretty much the same.
II. write out equations of the total net voltage of each loop, look there are only two loops.
You don't have your junction eqation. You have the two equations of the loops, but one of them is incorrect. Remember, you are traveling through one loop for each equation, emf is only on
one loop, not two! Each loop, what is there on each loop is one equation. Read my previous tread, what two important elements you should take into consideration?
Remember! You have three unknowns. How many equations do you need to solve the problem? It should be automatic if you set it up right. Junction equation is one, then the two are from the loops(hint hint)
OK...
I. I1 - I2 - I3 = 0 so, I1 = I2 + I3 (Time to find current so on to part II)
II.
Loop 1 (I hope):
+6 V - V1 - V2 = 0
+ 6 = v1 + v2
6 = I(R1) + I(R2)
6 = I(10) + I(20)
I = 0.2 A
Loop 2 (This one I'm really not sure about)
+v2 - v3 = 0
v2 = v3
I'm still working on the next part... someone stop me if I'm headed the wrong way! ;)
savoylen said:
OK...
II.
Loop 1 (I hope):
+6 V - V1 - V2 = 0
+ 6 = v1 + v2
6 = I(R1) + I(R2)
6 = I(10) + I(20)
I = 0.2 A
+v2 - v3 = 0
v2 = v3
Label the Is accordingly I1 I2 I3 etc...
you are trying to solve for values of each I, and you have to distinguish them.
Yea! I take it then that my two loops look good!
As for labling the Is... I thought I did that in part 1 above!? based on the figure in my first post.
Using I1=0.2A for 'loop 1', I get 2 volts for R1. Where go I go from there?
labels the Is for each loop equation
then you can solve for each I by deduction
Well, I just can't seem to 'get' this... sorry.
I keep getting the same wrong answers, but thanks for the help. If you have the solution for me that would be great for next time. SOrry to be so dense on this one!
This is where I ended up (just we can all see just how confused I am)...
From my figure (in post one);
I1 = 0.6 A; I2 = 0.2 A; I3 = 0.4 A
V1 = 2 v; V2 = 4 v; V3 = 4 v
The reasoning goes like this...
For the first I1 current, its just Ohms, 6v/10 ohm = 0.6 A
starting off on the first loop with Kirchhoff gets me,
+6v -V1 - V2 = 0
6 = IR1 + IR2
I = 0.2 A (for the 'first loop' circuit)
so, in V1 = IR1 = 0.2(10) = 2v
V2=I(R2)=0.2(20)=4v
Kirchhoff for the second loop gets me, V2 = V3 = 4v
Ohm's law gets me, I3 = V3/R3 = 4v/10 ohm = 0.4 A
This seems reasonable... my loop volts seem to zero out AND my current nodes seem to work (what goes in, comes out).
Anyway... that's what I'm turning in, we'll see how it goes.
Thanks! Savoy
Okay, I give up here is how you should solve it
Junction equation: I1=I2+I3
Loop1(going clockwise): 6-10I1-20I2=0
Loop2(going clockwise): -10I3+20I2=0
Then solve for I1, I2, I3
I used those (see above)... where did my logic break down?
From your loop one, I = 0.2 A (at the junction)
so I know 2A flow into the junction.
From your loop two, I'm left with 10(I) which is also 0.2A. (whichis nice for proving conservation, but how do I 'split' it?)
Yes the current get spit at the junction, hence I1=I2+I3. But, also it can be written as a equation of net Junction equation which is I1-I2-I3=0, is this not true? Can you relate this to the other two equations? When you solve circuits with mulitpul loops involving more than one emf you may appreciate Kirchoff's method.
OK, here I go:...
Junction: I1 = I2 + I3
Loop 1: +6 -v1 + v2 = 0
Loop 2: -v3 +v2 = 0 | v2 = v3
Solving for I1, I2, I3
Junction: I1 = I2 + I3 | v1/r1 = v2/r2 + v3/r3
v1/10 = v2/20 + v3/10
2 v1 = v2 + 3 v3 (v2 = v3) | 2 v1 = 3 v(2-3)
v1 = 3/2 v2
Loop 1:
6 -v1 + v2 = 0
6 -3/2 v2 + v2 = 0 (subbed)
6 - 5/2 v2 = 0
6 = 5/2 v2
v2 = 2.4 v
v3 = 2.4 v
v1 = 3/2 v2 = 3.6 v
I3 = V3/R3 = 0.24 A = 240 mA
I2 = v2/R3 = 0.12 A = 120 mA
I1 = v1/R1 = 0.36 A = 360 mA
I'm sure there was an easier way, but this is where I ended up. Thanks! Savoy
1. What is Ohm's Law?
Ohm's Law states that the current through a conductor between two points is directly proportional to the voltage across the two points. This relationship is expressed as V = IR, where V is voltage, I is current, and R is resistance.
2. How does Ohm's Law relate to Kirchhoff's Laws?
Ohm's Law is one of the fundamental principles used in Kirchhoff's Laws, which are a set of rules used to analyze electrical circuits. Ohm's Law helps to determine the voltage and current values in a circuit, which can then be used in Kirchhoff's Laws to solve for other variables.
3. What is Kirchhoff's Current Law (KCL)?
Kirchhoff's Current Law states that the algebraic sum of all currents entering and leaving a junction in a circuit must equal zero. This means that all current that flows into a junction must be equal to the current that flows out of the junction.
4. How is Kirchhoff's Voltage Law (KVL) applied in circuits?
Kirchhoff's Voltage Law states that the sum of all voltage drops in a closed loop in a circuit must equal the sum of all voltage sources in that loop. This means that the total voltage around a closed loop must be zero. KVL is used to analyze circuits with multiple voltage sources and to determine the voltage values at different points in the circuit.
5. Can Kirchhoff's Laws be applied to all types of circuits?
Yes, Kirchhoff's Laws can be applied to all types of circuits, including DC and AC circuits, series and parallel circuits, and complex circuits with multiple components. These laws are fundamental principles in circuit analysis and can be used to solve for various variables in a circuit.
